Good morning!!!!
   / Good morning!!!! #204,951
Good Morning Happy,
What my boss does, is after tank removal from basement we cut the tank in half with a sawzall and dump Speedy Dry in and just keep mixing that with a shovel until all the oil and gunk residue is dry. Then bag that and bring the cap metal in to the recycler. Works well, hope that helps 😉
Thank you!! I will give it a try but won't be cutting it in half ;)
   / Good morning!!!! #204,952
Good Morning,
Ct, 31 to start going to 46. Sun was out but it looks like clouds moving in.
My friend that also owns a house in Vermont was kind enough to bring a bed extender over yesterday after noon. This thing slides into the tow hitch and then tees off to support longer boards. The Trex boards are 12ft so they stick out the back past the tail gate over 3 ft.
Ok my other big question is that I see online that all SS recipients need to show up at their SS office to prove they are still alive. Is this more fake news? Because I haven’t heard anything about this until this morning 🥲
Hope all have a good day 🙏
   / Good morning!!!! #204,953
Good morning, the low is 19 and going to a high of 34°F. Wind NNW 8 mph. Periods of light snow.
We've got about 1.5" since the last time I plowed. Tomorrow maybe flurries and Saturday is the one to watch out for...Freezing rain.
My 'winter home heating oil' is getting down almost to the point of needing to top off the 500 gallon tank. Trouble is that I probably wont be able to top it off until maybe May, which is after the refinery changes over (change over is mid April) to summer fuel. So I have been looking at anti-gel formulas for the furnace oil. I have settled on Power Service in the white bottle. 2 jugs (64 oz) of it should treat 500 gallons of #2 diesel/home heating oil. I am thinking that the first jug should bring the gel point down to about -1F and the second one will bring it down to -40F. Correct me if I am wrong.
So, I top off the tank in summer (when the price should be cheaper) and come late October dump in one jug and coast on that until the temps get down near 10F then dump in the other jug. I do have a means of circulating it.
I think this will work, what do you think Scott?
Town and dump run today and maybe fill up my empty fiver with high test gas for the genny. That will bring me back up to 15 gallons on top of the 5 that is already in the genny.
There is my day planned out.
Have a safe day all
   / Good morning!!!! #204,954
Good Morning,
My guess is IF you've got a few hours to waste and your immune system is up to snuff, then why not? Can you phone them and ask them that same question?
   / Good morning!!!! #204,955
Good Morning
37° and overcast, high of 47 predicted, with continued overcast, but no rain.
Yesterday’s breakfast was good lots of conversation about the topics dominating the news cycle.
Got the fireplace cleaned out, did some 3D printing and drawing, definitely getting faster at design work.
I removed the ashtray from the little plane and designed a cup / phone holder to go in its place.
I was pleased with the way it worked out. I am realizing how important 3D modeling / CAD skills are to fully benefit from a 3D printer.
I did help neighbor get wires to his pond, that project was the textbook example of a CF.
It started when he called and said that he couldn’t get the string through the conduit. I had instructed him to tie some binder twine to a plastic shopping bag and suck it through the conduit, a little over 300’ of 3/4” PVC.
So I packed up my trusty Stihl vacuum and the adapters that I had made for conduit and headed over. It made short work of the task at hand. I think his problem was trying to cram an entire shopping bag into the 3/4” conduit.
While I was there, I figured I’d continue and get the wires pulled, so I dispatched him to get a pair or jack stands and a pipe or bar that would fit into the reels of wire while I pulled a rope through the conduit with the binder twine.
The first piece he brought to support the reels was aluminum and bent like a banana before I had the last spool on it. He couldn’t find anything stronger, so I used a step drill to open up the spools to accept a broomstick.
The bundle of wires (4 number 10’s) was right between the two sizes of pulling grips that I brought, but i figured the bigger one would work fine as long as we kept tension on it.
And it did right up until the person pulling the rope got tired. When he resumed, the last 30 feet of rope came out with the grip and no wire. (My wire tugger was locked in another friends garage). So I had to pull all the wire out and repeat from sucking the twine through. I ultimately prevailed just before sunset.
Be interesting to see what today brings.
   / Good morning!!!! #204,956
Nothing would surprise me but this is from ssa site
   / Good morning!!!! #204,957
Good morning TBN!!
39 this morning. Coolest day of this week. Only about 69. I too see 80s in the forecast.
Not to much yesterday.
Changed the forks for the 4-n-1 Got some seat time spreading sand around the tank to contain oil. Also picked up some brush the wife created .
Unloaded the truck and the put genny and Plasma back on it. That should be all I need to finish. Still have to figure out how to get oil and sludge out. Any suggestions appreciated. Going to be a really sloppy job!!
Dr.s appointment this morning. Not really sure why but suspect it's more of a wellness check.
After that I may try to quit procrastinating and just finish cutting tank up.
Nothing else planned but we will see what the day holds.
Time for a second cup.
Everyone have a great and safe day!!
Saw dust and a match.
Could shovel it out, then burn it.
   / Good morning!!!! #204,958
Good Morning,
Fake news.
   / Good morning!!!! #204,959
Good Morning Again,
NHBX, thanks I see that you only need to appear in person if you’re trying to change your DD bank info.
But thanks for the link 😃.
Bill, that sounds like it will work to me, especially if you have a way to recirculate as you just said. We use a product called Hot, it comes in a pint bottle and we use it during the winter months on all outside tanks. Especially those that are on the north side of the customers home. Usually one bottle every delivery during winter on a 275 gallon tank. If it’s a larger tank then 2 bottles.
So I think your plan is a good one. 😃
2007 TEREX ADVANCE FD3000 FRONT DISCHARGE AWD MIXER (A59575)
2007 TEREX ADVANCE...
2016 Butler LT-1619-WL T/A Flatbed Trailer (A56858)
2016 Butler...
DEUTZ MARATHON...
2022 Bobcat 68" Bucket Grapple (A57149)
2022 Bobcat 68"...
2016 Ford Explorer AWD SUV (A56859)
2016 Ford Explorer...
SEMI AUTOMATIC QUICK CHANGE FOR MINI EXCAVATOR (A58216)
SEMI AUTOMATIC...
