Good morning!!!!
   / Good morning!!!! #202,401
Good morning TBN!!
29 this morning but warming quickly. Should be in the 50s this afternoon.
Not a lot yesterday. Did a dump run and ran some errands in town. Went to Lowes and bought an 8 ft Werner step ladder for $69. The six foot I have is just a little too short to get to higher shelves and garage door workings.
Walked the dog plenty. Got the tractor started and let it run a half hour or so. It started on it's own Always a plus especially with the weather and the battery that's in it
   / Good morning!!!! #202,402
Good Morning,
Vt, 21 to start going to 30 ! Partly overcast skies and I could hear the wind last night but it seems to have slowed down this morning!
Drew, hopefully they can figure out the issue with over heating on your new vehicle!
Paul just curious on your plasma table issues, you mentioned tip getting plugged up. Is there a Z axis on that table ? Just wondering if it might have something to do with initial start distance from the work piece and rate of feed to pierce the plate ? Of course I know absolutely nothing about plasma cutting !!😉 Good luck finding the issue ! 🙏
Pj, nice fix on the breaker issue, love the easy fixes ! 😉
Delivery of new stackable washer/dryer went well. The two delivery guys came up our DW with this huge box truck, the driver didn’t want to attempt to turn it around up here so after the delivery they backed down 800 ft of DW ! Looks like they almost got stuck in the culvert by the road but managed to get out ! 😉
Today I will try and spend a little time out in the shop, since it looks like we won’t be leaving until Monday!
Right now I’m sipping coffee in fron of the wood stove ! But need to get going soon !
Hope all have a good day ! 🙏
   / Good morning!!!! #202,403
Yes there is a Z axis.
The sequence is that it drops down to sense the height of the surface by seeing the drive motor current rise as it stalls, raises to .150”, initiates a pilot arc, then lowers to the .060” cut height. The tricky timing is in the delay from when it lowers to cut height to make the pierce until it starts the actual cut, as well as the lead in distance and angle to the cut line.
The actual cutting distance is maintained by a closed loop that monitors the cutting voltage and drives the Z axis. If the cut height increases,so does the voltage required to maintain the arc, and conversely if the voltage dips, it raises the torch. This lets it compensate for a surface that isn’t level.
I am getting a decent handle on it, changing parameters and seeing the result has been a big help. Much less frustration than trying to learn on a part that I need.
   / Good morning!!!! #202,404
good morning, 32 per the Apple Watch going to 40 by 1:00 PM. nice change
Wife sleeping longer this morning. Good for her she needs the rest
Plan to get some steps in today and bring up more firewood. Also a trip up to the shop to do some clean up
David, Cody was back to normal after the seizure. He has had about one a year for the last few years. Not sure what it is causing it. Two different vets have examined him and done testing
   / Good morning!!!! #202,405
Ahhh...37 outside right now. Heading to upper 40's.
Should get some significant ice melt the next few days. Don't recall large portions of the driveway and yards being this icy this long in the decades we have been here.
On icicle watch, will it come down today? How much will it grow. Points to ponder for sure.
Hope all have a great day. Be safe.
   / Good morning!!!! #202,406
Morning, 34 going up to 40 and partly cloudy.
Yesterday did not go as planned.
Water dripping from the ceiling in the Apartment garage and turning to ice.
Got heater fixed, air intake iced.
But now have a burst pipe in closed off ceiling.
The ice skating rink around the tractor was not much fun.
Here goes some $$ :-(
Sorry to hear about truck problems Drew - hope it's something simple, good mech hard to find.
Well, might poke some holes in the ceiling and see where the pipe burst. Could be anywhere in a 10-15' area. Also ordered a temp alarm for the garage. We do not go up to apt every day and did not notice it cold the day before, so probably died during the day and did not notice until next day. I was up there Monday and all was fine...
Be well,
   / Good morning!!!! #202,407
Good Morning.
Day started at 20°, should reach upper 30’s. First day above freezing in at least a week.
Yesterday was a slow moving day, helped youngest son fit some metal thresholds, that involved drilling and countersinking them as well.
We set up a crude fixture in the Bridgeport to countersink them, taking advantage of a depth stop to make them consistent.
Worked on the heat loss calculations for my buddy, dealt with a burst frozen pipe at a neighbors, went for short visit with oldest son and family, and then home dinner and a movie in front of the fire.
Son took grandson flying in the little plane, grandson flew most of the time.
The TV and audio system built into the great room makes a great home theater. Wife occasionally complains that the TV is too big, but then when watching a movie enjoys it.
Not sure about today’s agenda, a Costco run has been mentioned, I would like to make an extended door strike plate, that would involve a drawing in fusion, cutting it out, making the bends,,drilling and countersinking the holes and then having it powder coated. I haven’t been able to find one commercially made that is long enough, so I will likely make one.
Here is what I’m dealing with-
This afternoon might be a good time to go to Costco, as there will be a lot of people home watching the Eagles playoff game.
   / Good morning!!!! #202,408
67°F and .01 inches rain
Did get some mowing yesterday afternoon after it had dried out some.
More an energy conservation day with watching playoffs.
Prayers for all
Be safe
Have a great day
   / Good morning!!!! #202,409
Good Afternoon,
Thanks for the detailed explanation Paul !
(2) UNUSED 3500# IDLER AXLES (A51247)
(2) UNUSED 3500#...
1991 Grove RT740B 40-Ton Rough-Terrain Crane (A51691)
1991 Grove RT740B...
HYD PUMP & TANK SET (A51248)
HYD PUMP & TANK...
2023 BOBCAT T770 SKID STEER (A51246)
2023 BOBCAT T770...
2023 UNVERFERTH 632 LOT IDENTIFIER 165 (A53084)
2023 UNVERFERTH...
2017 Yale GLC050VX 3,500 lb LPG Forklift - Powershift, Aux Hydraulics (A53472)
2017 Yale GLC050VX...
