Good morning!!!!
   / Good morning!!!! #194,221
Morning all! 71 going to lower 80's today. Way to wet outside to get anything done out there.
Waiting on visitors today for inspection of the furnace install.
Wagon wheel delivered and now waiting on them to paint and install before I get another one.
Played in the shop a bit and made a container for the master bath and a couple wands for possible sale. Waiting on reply from requester.
Not sure what will get done today. Think I might be part of the procrastinators club!
Hope everyone stays safe and healthy!
   / Good morning!!!! #194,226
Good Morning!!!! 63F @ 6:00AM. Abundant sunshine. High near 95F. Winds S at 5 to 10 mph.
Damned squirrel in addition to costing a box of towels almost gave me a heart attack when came scrambling out of the box and up my arm before jumping to the floor.
I think I forgot to mention that almost the same thing happened to me when I was looking for popped fuses on the firetruck last week. I found a mouse nest in the glove box, and when I opened the ash tray a mouse jumped right into my lap. It's next hop was to the floor, and I was a second too late trying to stomp it with my boot. Instead it made it out the door to live and restore its home in the glove box again.
OK, valve tap gone at idle, but still present at the 2K rpm range. Not good.
What engine is it? If it's the 7.3L Diesel, it won't start or run if it looses oil pressure. At two quarts, it wasn't completely out, but if the oil level was below the pickup, could be the cams and lifters suffered some damage.
We're dry and hot here this week too! Make sure you close the doors and windows......
I haven't had any doors or windows open for ventilation for at least a month because the temperatures have been so hot, and for the last week, because there's enough smoke in the air to make it unhealthy.
I'm wondering if I can get take out from there, good food but in a very quiet rv.
I was warned away from The Big Texan by the locals in Amarillo, Drew. They said the food is not very good. Lincoln Steak House seemed to be their favorite.
I was very happy when the Honda generator started up after only a few seconds of cranking yesterday. I installed a propane conversion on it a few years ago, and haven't used it much since. It ran for most of an hour up at the gate powering a medium size hammer drill I'd hoped would make short work of the concreted in and burned off at the ground fence posts there. No such luck, as I only got about a foot down on one post in all that time. Gonna need the full sized electric jackhammer for this job, and it's down south. But the list of things to do here keeps growing, so I'll need at least one more van trip before I can start driving the Toyota up here again.
While I had the generator hooked up, I ran my neighbor's pipe wrenches back to him, and we hooked his 120VAC welder up to the generator so I could fine tune the propane mixture while it was under load. He didn't have a replacement 1" PVC shut off valve, so when I mentioned I was just going to the local rip off hardware store to save me a trip to town, he decided to ride along and pick up a roll of stamps. The big van got his stamp of approval, too. Mine, too, as it made it up both of our steep gravel driveways loaded with half a ton of firewood with no trouble at all.
Back home I made a bad cut on the PVC when I went to replace that valve, but fortunately had a fitting in the box that would work. Doing it that way didn't let me re-route and simplify like I'd intended, but it ended up being less work.
Once the sun got lower and it cooled off a bit I dumped the water out of the Kubota side-by-side's radiator and mixed up a gallon of 50/50 antifreeze. Left it to drain overnight and called it a day.
Today will start with filling up the Kubota radiator, then spraying another tank or two of glyphosate on the yellow star thistle that always comes in this time of year. Not sure what the rest of the day will bring, but there are lots of choices.
   / Good morning!!!! #194,228
Good morning! Low of 60°, going up to 92°, no rain. The monsoon is supposed to kick back in Thursday or Friday, so chances going back up. Temps will be too!
Researched the issue on the daughter's truck. Two very common issues not too expensive to fix, just very time consuming. The third one is less common, a little more cost, but even more time consuming. The last issue (which is related to low oil) is the worst, she'll get to decide if a full rebuild is worth it vs the value of the truck....
We're going back up in a couple of weeks and I'll take some tools with me to diagnose it. I have a good suspicion that it's the third common issue. Fingers crossed that I'm right.
RNG, it's the 6.8L V-10. Known for breaking exhaust manifolds, spitting out spark plugs at high velocity, and oil starving the cam phasor / tensioners. Her's was the last year before they changed head design. I'm thinking that it's getting ready to launch a mini missile!
Feeling much better by last evening. Didn't do a blessed thing yesterday except hold down the furniture. Startled awake again last night at 01:30, only tossed for about an hour.... getting better.
I am planning on a small project that's been on the back burner.... grinding down 2 cast iron pans, then re-seasoning them. Can't say that I procrastinated on doing them, just other things got priority.
Buppies, take it easy and heal quickly.
Drew, had to look up that squash, yes, strange looking.... almost more like a gourd. Hope tomato delivery successful. When is your tentative scheduled stop here?
Time to go catch some fresh morning air on the porch. The BIL is also enjoying the peaceful surroundings. Far different than his home of San Jose.....
Everyone have a great day!
   / Good morning!!!! #194,229
Hot and humid days, now... Working in the new shop with A/C on is nice. The SIL said his little Kubota B1550 started making a racket and smoking while bush hogging, so he shut it off - way back from the road. Turns out the water pump went out. Worst one I've seen. The wobbling fan blade knocked a hydraulic clamp loose from the cooler, but the smoke was from the belt - the pump was so bad it was locking up. I'll replace some original hoses, while I'm in this deep. Taking the hood off and the radiator out made access easier. Got a chance the clean the radiator and lower panels under the motor good too. Yes, there is a stand under the raised loader...
   / Good morning!!!! #194,230
Ted, route 66 rv campground, Edgewood NM, Sept 29 for two nights, have reservations
off on refrigeration errand of rescue
taking my rv portable electric fridge over to neighbor across street whose fridge just died after 29 years.
They can set that on freezing and I'll take them a cooler with cold packs for other stuff.
not doing any good just sitting in rv.
2023 New Holland CR10.90 Combine - 330 Engine Hours - 251 Separator Hours (A56436)
2023 New Holland...
2024 CATERPILLAR 255 SKID STEER (A52709)
2024 CATERPILLAR...
LOT: (2) Rolling Nut & Bolt Carts w/Bins & Contents (A59076)
LOT: (2) Rolling...
(APPROX. 26) 4' X 8' X 3/4" OSB SHEETS (A52706)
(APPROX. 26) 4' X...
New Wolverine Sid Steer 3PT Hitch Quick Connect (A59000)
New Wolverine Sid...
2016 Ford Transit 250 Passenger Van (A55852)
2016 Ford Transit...
