Good morning!!!!
   / Good morning!!!! #191,711
My wife was saying how tired she was getting carrying water jugs around to water her flowers, so mentioned a couple of you use water carts...RS, did you rig yours up yourself?
Yes, I did.
Started with a mesh bottom cart that I think I picked up from TSC when they had it on sale. Probably less than $100.
Something kinda like this:
It was the kind that had a handle that rotated so you could pull it by hand or tow it with a garden tractor. I eventually removed that (because it too flimsy for towing) which left us with just a tow hitch.
Then I picked up a used plastic 55 gallon drum that was used to ship dye for coloring wood mulch.
Rinsed that real good and then added a 1/4 turn valve I got from TSC ... think it was 1 1/4" pipe like this:
Then adapted that down to a male garden hose connection and stuck a 3' Flexzilla garden hose whip on with a quick-connect coupler on the end.
Stuck a small plastic 1/4 valve on the 3/4 vent hole to vent the drum while filling and so I could close it up when hauling.
Built a cradle out of old 4 x 4's to hold the drum on it's side.
Only thing to be aware of is that you talking around 500 lbs when it's loaded.
We carry a short chunk of 4 x 4 to chock the wheels ...
I searched a few sites online like TSC, Northern Tool and Amazon, and didn't find but one that seems practical and affordable. May get that for her birthday coming up.
Yeah ... homebrew is probably better.
Anything decent they'll probably want to gouge your eyeballs out.
   / Good morning!!!! #191,712
67° and overcast. Not calling for rain.
We pull the hose out to water, except some she uses a water can.
LS, we were surprised.
Hummingbirds chasing each other, feeder needs a refill.
Got old rotary mower unloaded, cleaned up behind the barn. Made new rack to hold unused pipe and fence rails, old one getting rotten. Moved other stuff around. Straightened tines on cultivator.
Unloaded PHD from truck, and put other stuff away. Kind of cleaning up some in the barn also. Lot more needs done. Nice day to work outside.
Yard needs mowed, but not today.
Snagglepuss just layed on my lap.
   / Good morning!!!! #191,713
Yes, I did.
Thanks. That's quite the rig!
   / Good morning!!!! #191,714
Went ahead and finished stoning the area behind side of barn, 12 ft out from edge. Then rearranged more junk. Put landscape fabric under the stone. I did get most of the grass and seeds off the top of the mower.
It’s not all level, as the back corner would drop about a foot
   / Good morning!!!! #191,715
Wish me luck.
The '69 car I just got the turn signal switch broke after I bought car but hadn't taken delivery, so he sent car along with a check he insisted paying me.
Years ago someone "boogered" switch wiring splicing wires. I've replaced them before but it's major surgery. I have lots of parts I've collected over the years and manuals so no big deal...it's just at 72 this year I cramp up, forget things, etc.
If I was only 20 again! (Even 60! ).View attachment 874976
   / Good morning!!!! #191,718
Wish me luck.
If I was only 20 again! (Even 60! ).View attachment 874976View attachment 874977
I know the feeling, just rolled over to 73. I bought the factory trailer brake controller for my pickup last year and still haven't installed it because it's such a pain to get my carcass down into the foot well to install and put in the bypass cable to update the software to be able to use it. Fortunately I seldom tow much and I have borrowed the farms truck or had one of my brothers do what towing I've needed.
   / Good morning!!!! #191,719
Wish me luck.
Oh my, sorry for y'alls' woes. I have felt that my body is "winding down" too a lot in the last year. I'm about 8 years behind y'all. My get up and go has got up and went. I have non diagnosed (let's call it tired leg syndrome)....it takes a bit of time to get out of the car after my hour trip...waking the legs up. I can't walk far distances like over 1/4 mile very easily. I want to buy me an electric scooter or something to get around on campus.
I worked on my daughter's 2010 car under the dash last Saturday. One of her blend door actuators broke. But I believe the main problem is the climate controller. It has variable cold/hot for both sides and it does not send a good signal to the actuator. The climate controls come in 2 parts on this car, the front end with all the dials and such, and the back "brain" part. I want to take apart the front part, and see if I can clean up the pots on the hot/cold to fix it. But with the heat down here, I don't want to attempt it unless I have the backup new part on hand, just in case I botch it and need the new part.
Has anyone noticed, that while trying to drive a modern car down the highway with the windows down, that these crazy resonant wind pulses can start happening with the windows at various openings? I don't ever recall that happening on older cars like what Fuddy is working on...and I've driven in a lot of post WW2 cars. Mainly '50's and newer. but most had no A/C. Maybe because the old cars were built with thick enough steel that doesn't flap in the breeze...
Not sure if I've mentioned this yet so forgive me if I have. Our 14yo son scored 99th percentile in our state on his math achievement score. He believes he missed one problem on the timed test, "probably made a simple mistake." He's 1 year ahead of the class already in math. Hope cal1 and cal2 come to him well (hope he has a good teacher for those). He will be a freshman this year, and his test score stated he already had a high enough number to graduate HS. I hope he does well at whatever type of job he ends up with, because as things stand now, I believe he's going to be one of those people who have to take their vehicle to a shop to get it repaired.
My pressure washer conked out yesterday....while my son was using it. Its always something right? It is old, so no major loss, but it sux not having a PW So, I hate to say this, but it could've been an operator error. While my son is a math wiz, he's not an engine wiz yet. Not sure what the issue is yet, we had used it just some days earlier, but I was there and it worked good. It sputters, and almost kicks back at low rpm. I cleaned the carb, no worky. Took out the cheap pump's regulator. . It was designed with some internal springs on the shaft's smooth cylinder area, to keep it from being taken apart. but I still took it apart....Arghh! One place wants about $90 for a new regulator, and I believe I can get a whole new pump for about $160....what to do, what to do. I might take the pump off, just to see how the motor runs unloaded.
You see, as a machinist, I hate having to buy badly designed parts, but the regulator has this small long threaded shaft with details that you really need a screw machine to make them correctly. I might dig through my box of cat pump parts that my old job had thrown in a dusty corner to get them out of the way. I might have enough parts for a whole pump assembly. That was the best job bonus at my old company, they would put all these failed projects in a junk room, and every couple of years they would need space and I could just take home a bunch of stuff. Sometimes they wanted a few dollars for it, which was roughly equivalent to the scrap value. I'm a collector and gatherer....barn is chock full 'o stuff. While my new job has some shop resources, it is not really equipped to make a diverse array of parts.
Mostly, glad you got some rain.
Popgadget, it amazes me how you can jump from one plane to another, I know they are all SO different. glide slopes, stall speed, VNE, the list is so long of things you need to know about each one. Amazing.
Fuddy, that city in the middle of your map has me chuckling every time I hear about it...might have to get the wifey a glass of wine....hehehe
Billy, if you have slopes, I would forego a wagon water cart and install some buried water lines, closer to her beds. Or set up drip lines to avoid watering altogether. I still have my "tractor" style sprinkler, but it gets stuck if I try to use it on tilled garden soil....only on grass usage.
Wag, that sounds like a cool morning. Hope all is well down under.
Bupps, the allergies are hitting here too. Get some rest.
My son has pink eye/conjunctivitis today, after having fever/no energy all weekend. I told him that "friend who happens to be a girl" is giving him "cooties"...my wifey laughed. (They have not kissed yet, nor have they had the time to do it.)
Drew, please share your travels here. "There, and back again".
Prayers for our team.
PALLET OF 11 BARBED WIRE ROLLS (A58216)
PALLET OF 11...
2023 Chevrolet 1500 Silverado Z71 Crew Cab Pick-Up Truck (A56858)
2023 Chevrolet...
2019 International MV607 Cab and Chassis Truck (A56858)
2019 International...
Mini Skid-Steer Steel Mounting Plate (New/Unused) (A59225)
Mini Skid-Steer...
KUBOTA SSV65 OPEN STATION CAB (A52706)
KUBOTA SSV65 OPEN...
2017 John Deere 5075E (A57148)
2017 John Deere...
