LouNY
Super Star Member
- Joined
- Jul 4, 2015
- Messages
- 14,236
- Location
- Greenwich, NY
- Tractor
- Branson 8050, IH 574, Oliver 1550 Diesel Utility (traded in on Branson) NH 8160. Kioti CK2620SECH
Or go with expanding grout, offered in 3 different temperature ranges for use in most climates;Verified the wires going to combustion motor is getting 120v, but motor not working.
Removed the motor from stove. Harman stoves are very easy to work on.
Connected to 120v on my work bench, still not turning.
Got set screw for the fan blade off, it was tough.
Need to order. New ones don’t look as robust as the original.
Unopened tube of RTV to seal stove pipe is all dried up. Guess it’s been on my shelf too many years.
SDS max bit should be in my mailbox, won’t get to that today probably.
But I did, drilled couple dozen holes in rock . Now if I just had 0 deg days and some water.
Amazon.com
