Good morning!!!!
   / Good morning!!!! #184,241
Good Morning Guys,
Ct, 13 to start going to lower 20’s !
PopG, you are getting close if your in Newburg, Ny ! Less than an hour from out Ct home ! Safe trip to you today !
Kilroy, nice score on the ice melt ! Doesn’t get much better than that other than Free ! 😂
Ron, great picture of your wife with that monster of a fish ! She looks like she truly loved fishing and being with you on the boat !
Phil, beautiful job on the plates and platter ! I’m thinking that your screws must be fairly short going into the piece from the faceplate ! Or do you turn a set diameter and use a collet for the secondary turn ?
Will go for a long walk or hike today and maybe some German on Duolingo !
Don, just curious, do you pay for Super Duolingo or do you just use the free version ? My problem is after I use all 5 hearts, they kick you out for the day if you are unwilling to subscribe to the Super version ! Frustrating !
Hope all have a blessed and safe day ! 🙏
   / Good morning!!!! #184,242
Made the second stop at a gas station with the Prius since I got it in September, it took just under 8 gallons, most of my driving is within its EV range, so I don’t use much gas, but it is completely seamless when it makes the switch from EV to Hybrid.
That looks like quite the tool for snow removal, Paul.
Do you worry about ethanol laced gas going bad before it gets used up in the Prius? Or has Toyota figured out a way to deal with the alcohol? Or maybe you can find E0 that doesn't cost an arm and a leg? Out here it sells for $6-$8 a gallon, if you can even find it.
   / Good morning!!!! #184,243
They shed bark and leaves profusely, establishing an excellent tinder pile underneath them that quickly spreads ground fire to the trees themselves.
I lost the eucalyptus tree I planted back around 2005 last year. It was a fast grower. It was everything you say but I still miss the fragrance of it. Thought about planting more with better access to water.
   / Good morning!!!! #184,245
My wife has used Super Duolingo for 2 years and I just used the free version. I did cut out a lot of heart loss by writing down the correct answer so I don't make the same mistake twice. My wife is consistent and uses Super every day and also takes classes when given by the neighborhood Language club. She understands the Spanish people in line at the supermarket. If we had a maid or lawn service I'm sure she would be able to communicate with them.
   / Good morning!!!! #184,246
I haven’t worried about it, perhaps I should. The gas cap says it’s ok with (Yikes!) E20, and it does run the engine every 200 miles or regardless of the battery state of charge just to lubricate it and prevent corrosion.
One more thing to keep me up at night………..
   / Good morning!!!! #184,247
However, I’m planning on putting a fireplace in my new “in law suite” that will become my new home. I like tending the fire and the radiated heat, even though I realize I’m sending conditioned air up the chimney.
You could install a fresh air inlet for the stove to breath through if you put it on an outside wall. That way the stove is not using conditioned air from inside the home. If my experience with the Quadrafire stove up north is any indication, it'll also draw very well, making the fire incredibly easy to start.
I'd love to install another one down south, but the outside wall where it would best fit is at the low side of the roof. I think extending the stove pipe that far above the gutter would not be very structurally sound, and would probably be ugly. There was a fireplace in the home, but the previous owners took it out and installed a sky light in its place at the roof peak in the center of the room. So drawing air from outside is a bit of a challenge. But I wonder if the stove could somehow be rigged to breath between two of the walls of a triple wall stove pipe? Probably not, as the joints in those pipes don't look like they are open top to bottom. Worth checking into, though.
   / Good morning!!!! #184,248
btw my budget to build a 1,000ft residence, here in CA, is $500k. It will be very close to that-- if we proceed. Not sure.
Not sure were you are in NorCal, but in this area (just a few miles from Paradise, the one that burned in the Camp Fire), there is so much insurance money flowing that contractors are getting half again or twice what they were before 2018. The estimated replacement value for my home there has gone from $500k to $740k, and the premium on the insurance policy has gone from $800/year to $3000/year.
And speaking of insurance, many insurance companies are choosing not to sell homeowners insurance in California any more. I insured the new place in Orcutt with Farmers last year, and last December they informed me they would not be renewing the automotive coverage I signed up for at the same time. I suspect that when the homeowners policy renews in a few months, they will choose not to, even though the Orcutt home is not in an area with elevated wildfire risk.
   / Good morning!!!! #184,249
I don’t want a fireplace for any practical reason other than aesthetics and to have an open fire to tinker with. Almost anything that makes the fire more efficient is counter to my prime objective.
The reality is that the most efficient wood stoves are almost as efficient as a typical oil burner, and way behind modern gas and heat pump efficiency.
I’m thinking about a classic stone fireplace, I could add a fresh air vent into it though.
   / Good morning!!!! #184,250
Morning all, 19 going to 33 and cloudy.
Son was out late last night for an open mike night we didn't know about. That will need to stop. All tired today.
I have the full office version pretty cheap from StackSocial. It's a real license, but cheap, not a subscription like I have at work.
back to work,
2225 (A58376)
2225 (A58376)
RAKE ATTACHMENT FOR MINI EXCAVATOR (A58216)
RAKE ATTACHMENT...
DRAGON 500 BBL FRAC TANK (A58214)
DRAGON 500 BBL...
1708 (A58375)
1708 (A58375)
2008 FORD F-750 SUPER DUTY (A58214)
2008 FORD F-750...
2021 Deere 333G (A53317)
2021 Deere 333G...
