Good morning!!!!
   / Good morning!!!! #180,851
68°F and no rain
Expect to get my system configuration tweaked to accommodate the bad part. Not a big problem as I had already done so when system was installed 4 years ago. Need to have the secondary generator auto start when/if voltage drops. I had this until I lent my Honda generator to a friend in need. Just have to put back in place and reprogram settings.
Then I should be able to get back to cleaning the BX fuel tank.
We do want to visit a good friend this afternoon. Terminal cancer and not having many good days. I suspect her time is short.
Prayers for all
Be safe
Have a great day
   / Good morning!!!! #180,853
For the curious, otherwise maybe disregard.
So as for my electrical issue.
My off grid system as do many others, has an Auto Generator Start system. Basically programming in some settings related to battery health can trigger a relay that starts the battery and system charges battery rather than inverting. Settings can also terminate this function. My problem is the Aux Relay, my trigger, has a problem in the stack and would malfunction, generator not start and likely the next load surge would bring voltage down to the system shutdown level. Hence no power.
Several work arounds without fixing the bad board. Rewire generator to another trigger/relay. Given size of my system I have at least 2 others. But rerouting the wires would be a PITA.
When this system was installed I kept 2 of my old inverters and had installer wire them in as a separate charging system. It shares same battery bank and some common info but connected to its own generator and control model. Also the ac output is not connected, but it could be its own source.
I did this to be able to run smaller, non propane(cheaper) generator. This newer system with increased capacity has been quite efficient and running generators less than 50 hrs a year and mostly during our rainy season. So when my friend Keith suddenly had a power issue it was a no brainer to pull the Honda out of the system and lend it to him. He now has a nice lithium battery power system and I got the Honda back.
Of course I took advantage of having this 2nd control module (Mate3) and used to troubleshoot my problems, hence the programmed setting are changed.
Thinking of taking the opportunity to relocate placement of the Honda and this will require rerouting control wire. Once back in service, this separate charging station would autostart generator when triggered keeping voltage up and my main system happy, not even knowing there was a potential problem.
OK, too much for some, but I know a couple of you read with interest. and I’m procrastinating.
   / Good morning!!!! #180,854
As a child did you think you would be running your own power station? :)
   / Good morning!!!! #180,856
Paul, re no two Costcos laid out the same…we only have one on the island and it drives me crazy they rearrange the layout periodically. Not only they racked items, but here they just finished a major refrigerator change.
   / Good morning!!!! #180,858
Thank you ! The first one healed up nicely in about 4 weeks time. Looking forward to seeing the world again. Those cataracts steal your vision slowly and you may not realize how bad your vision actually is until it's fixed. Amazing medical advancement for sure.
It took me a year to make the Dr appointment after my optometrist told me I would need the surgery... then the healthcare system and life's event took 11 months to get er done.
I recommend this for anyone affected with this problem.
Had both mine done. Even though I still have glasses, highly recommend.
   / Good morning!!!! #180,859
oh what a wet drive, all the way. Only one accident, at merge near Savannah two cars hit pretty hard. Then 17 to Charleston, nice road for a while, then really clogs up downtown. Very neat county park campground and I had no idea this night before Thanksgiving they would have the entire place decorated and there will be community drive thru. So many of these rvs must be local who dragged their blow up Santas and a ton of other stuff along with them. Glad I'm parked far back from that.
and it's pouring rain.
on the way out of campground this morning, had to stop and take a pic of this old SS. Not sure, think the crossed flags means a 396?
could be a clone
   / Good morning!!!! #180,860
I have a friend in Mississippi who makes up his own words ~ Amusing himself and others. 🤪
So many people on the list for this operation here. The Dr I used is very good and the wait was worth it. Friend in Kentucky got surgery right away ~ They put the wrong prescription in one eye and he had to go back, then other problems and he had more eye surgery...:oops: scared me. But glad I found a good one.
Got both my surgeries by being on call list and took advantage of others cancelling.
2017 Ford F-250 Service Truck (A56858)
2017 Ford F-250...
3ft Teakwood Cowboy (A57454)
3ft Teakwood...
4001 (A59228)
4001 (A59228)
2020 Westfield MKX 100-83 Auger with Swing Hopper (A56438)
2020 Westfield MKX...
Quick Coupler (A57149)
2007 DELTA GOOSENECK TRAILER (A58214)
2007 DELTA...
