Good morning!!!!
   / Good morning!!!! #166,041
Morning all, 33 going up to 51, and sunny-wind is calm for a bit, been blowing stuff around for the last few days.
PopGadget - tell the Mrs/ happy birthday for us
Maybe get some wire attached in the utility room. MiniSplit delayed due to funds (or lack of) for now. Might get some furring strips and sheetrock to at least get that wall ready.
PopG - how do you design your crossovers?
Be well,
   / Good morning!!!! #166,042
Good morning, 29 going to 52 today, still too wet to do much outside but it is drying nicely.
Fixed the phone issues yesterday although I am not happy about how this went down. Got a new iPhone thinking it was a phone issue only to find out it had the same dropped calls. After a lot of phone with calls to AT&T they finally fixed what was the problem on their network.
Popgadget, happy birthday to wife. Was the freezing problem with the Mitsubishi mini split?
Tomorrow morning early heading up to Mechanicsburg for replacing the charge cooler on the Sprinter.
Saw this story about man stranded in snow bank with no cell service sending his phone up with drone to send text for help and he got rescued
   / Good morning!!!! #166,043
Popgadget, that looks bigger than a 12 inch culvert pipe they are sitting on, did you go a size up or ?
   / Good morning!!!! #166,045
No it was the 14 SEER Goodman that is paired with a propane furnace for backup. I have “customized” it over the years with a Hyper Engineering “sure start” soft start device and the demand defrost control that is my current issue.
The sure starts are great, they reduce the starting current by a large factor.
The Mitsubishi is upstairs, it works flawlessly and reduces the load on the main system on the first floor.
   / Good morning!!!! #166,047
"That's a new low for our mailman."
It seems like something is wrong at the post office. Have the post people been so jerked around that they don't care anymore?
I think there's some of that going on, but what few conversations I've had with our postman leave me with the impression he likes playing the victim, always blaming someone else for his unhappiness, and fighting back against "the man" with his bad behavior. So I guess the people along his route are also part of "the organization" against which he is rebelling.
   / Good morning!!!! #166,048
Good morning! Low of 35°, heading up to 54°. Then the high jumps to 66° tomorrow. No precip.
Got the drip irrigation repaired, zone successfully watered. Starting to see a couple of buds on the lilacs starting to crack open. A couple of perennials starting to emerge.
Spring is around the corner.... that means getting another snowfall.......
Some piddling today, but not much. Knee is complaining...woke me up a couple times last night.
Everyone have a great day!
   / Good morning!!!! #166,049
I'd have to make some other expensive changes, like adding an Xantrex inverter/charger that is rated for lithium voltage.
Maybe not, Drew. I've seen quite a few lithium batteries that are designed for automotive use that have their own built in charge controllers, and are configured to use typical automotive alternator outputs in the 12-14 volt range. All that extra circuitry doesn't help with the cost, though.
   / Good morning!!!! #166,050
wow, another train crash, this time caused by a landslide on the tracks, engine went into New River, must have been mighty scary for that engineer.
cars can have radar and autostop, but trains are so heavy, like cruise ships, they take forever to stop.
lucky train was not full of chemicals
not sure how they can avoid this without huge expense in mountain areas
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
2016 Komatsu WA380-8 Wheel Loader, S/N 15080, PIN# KMTWA13OCGA015080, Turbo Diesel Engine, Komatsu (A59076)
2016 Komatsu...
2013 Ford Taurus Sedan (A56859)
2013 Ford Taurus...
HYDRAULIC THUMB CLAMP FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
2008 Ford F-250 Lariat 4X4 - 303,424 miles - 6.4L Powerstroke -Automatic (A56435)
2008 Ford F-250...
NEW Woods Reverse Rotation 5ft Tiller (A55301)
NEW Woods Reverse...
