rswyan
Super Star Member
- Joined
- May 12, 2004
- Messages
- 13,185
- Location
- Northeast Ohio
- Tractor
- Kubota B2910, Cub Cadet Pro Z 154S, Simplicity 18 CFC, Cub Cadet 782
40F and cloudy @ 20:00, heading down to around 38F for the overnight low with occasional rain showers.
Took 2 bags of garbage up to the road after Woman got a message from the trash haulers that tomorrow's pickup would not be delayed due to MLK Day. (Usually if a Monday is a holiday, they run one day behind)
Also took up 5 buckets of cat litter and compostables to the pile, plus some more stuff (tools, parts, etc) up to the shop including some burnables.
Compost pile has probably dropped a foot and half over the last couple of months. Next year's harvest should be good ...
Was 41F in the shop when I walked in, 72F when I came down for dinner. Threw a couple more oak splits in before I left.
Got a good bit of cardboard burnt ... and a path cleared to the bandsaw !
Unfortunately I looked a little closer at that flat stock - it's 3/8" thick not 1/4" ... which is way overkill. But I may end up using it since I have it. Not likely that it will get bent up.
Dug out the roller stand that I got for free from a neighbor and moved it over to the bandsaw, looks like it might be too tall. No matter - it seems like a nice solid unit which could be used for woodworking or other steel projects. Does need some clean up and refurbishment though.
Went over to the pole barn as well and verified that the large hose for the Shop Vac is indeed 2 1/4" not 2 1/2".
Also measured the thickness of the table top that will be used for the woodworking bench/table - it's 1 3/4" which should be sturdy enough I would think. It also has some framing on the underside that legs attach to, which looked to be 3" tall by 1 1/4" thick. Not sure if I'll end up using that or not.
Got one side of one chain sharpened, after I reset the machine to the proper angle. Will like go back up here in bit and do the one side on the 3 other chains and then reset it and do the other side on all of them.
Grabbed the drill guide and cardboard box of equipment manuals and paperwork to organize down here at the house.
Woman made cheese eggs and bacon for dinner, Nestle Tollhouse cookies just came out of the oven.
As mentioned (and linked by Jim) it uses a Dust Deputy 2.5, which is the updated version of the Dust Deputy and is designed for vacuums that use a 2 1/2" hose. They do make larger units as well that are a good bit more pricey.
Basically uses a shop vac + the Dust Deputy and the container it is mounted on which is plumbed in between the source (of dust) and the vacuum, to extract the majority of the dust and debris, lessening the need to change filters and maintaining vacuum performance.
Seems to have good reviews mostly, including from a number of folks that tried home-brew solutions with less than stellar results.
I'm going to design it as a point of use system, probably on wheels ... so it can easily be moved around to various machines if need be.
Links on Amazon for the components:
Dust Deputy 2.5 DIY Anti-Static Retrofit Cyclone Separator for Wet/Dry Shop Vacuums (DD 2.5 DIY) https://a.co/8n77pKe
2 1/2" x 20' Clear PVC Dust Collection Hose For Use with Dust Collectors with 2-1/2" Ports. Ideal for Shop Vacuums https://a.co/7GbIOFk
Eagle 14 Gallon High Density Polyethylene Lab Pack Barrel Drum with Metal Lever-lock Lid, 26.5" Height, 15" Diameter, Blue, 1610MB https://a.co/jl1T8ku
(I have a 30 gallon Safety Kleen drum up in the shop that I'm not using that I may use instead ... to save some $$$ ... if it looks like it will seal)
2 1/2 Inch Thumb Screw Key Adjustable 304 Stainless Steel Hose Clamps, Pipe Clamp, Worm Gear Clamps, Dryer Vent Clamp, Dust Collection, Automotive, RV Clamp 5 pack (2 1/2" Hose Clamps) https://a.co/0VGNasm
The clamps above will be for the permanent connections, the ones below will be for temporary connections to facilitate moving the hose around to various devices.
EZ-Release Dual Hose Clamp 2 Pack (2-1/2" Clamp 2 Pack) https://a.co/f7ZkQ5d
POWERTEC 70141 2-1/2-Inch to 2-1/4-Inch Reducer https://a.co/fOdqwGD
WoodRiver Dust Connection Flexible Hose End Cuff - 2-1/2” https://a.co/0vFfrma
Hope that helps.
Rswyan
Would like to hear more about your dust collector, something I sorely need.
Hope that helps.
