Good morning!!!!
   / Good morning!!!! #154,821
Good Morning!!!! 74F @ 4:45AM. Mainly sunny. High 102F. Winds light and variable.
Good luck with the skunk, Bird. It'll be nice to have it gone, but I'm not sure I'd look forward to the process of getting it there...
I guess I missed it, David, but what prompted the repair on the flail mower? Did you get tired of replacing belts on the old multi-belt setup?
Good find on the portable hot tub, Drew. Never knew there was even such a thing, yet that Amazon page provided links to a bunch more makes and models of 'em. Please hurry up and get one so we can see how well they work, OK? Is 104F hot enough to do any good for an old man's aching muscles?
Yesterday I got the security cam mounted on the solar panel pole at the front gate, and moved the pole to the new pivoting anchor. The two 3/8" holes in the pole were drilled without damaging the wires inside, and the only trouble I had with terminating the little Ethernet wires was forgetting to install the weather tight grommet in the camera before the Ethernet connector was put on. I took a guess at aiming the camera, and it turned out to be pretty much spot on, maybe the biggest surprise of the day. Another surprise was that the camera worked without any extra fiddling, and another surprise was finding it captured the UPS man dropping off a box that held the repaired cylinder for the red G/S motorcycle:
Maybe the UPS man saw the new cam, because it was the first time in quite a while he bothered to lock the drop box, even though he managed to make quite the noise when he closed the lid.😂
I wasn't quite so lucky when it came to the orientation of the solar panel on the pole, so I'll address that today. Also left over for today was getting the muffin fan installed on the network switch, but I did get it out of the box and verified that the thermostat on it worked. I'll also get the heads out of the dunk tank and take a first shot at scraping off the gunk. It usually takes multiple rounds of soaking to get all the deposits off.
   / Good morning!!!! #154,822
I was told the building isn't worth fixing, but I can't just leave it alone. It's a converted corn crib, with a fairly decent concrete floor. I've been working on this roof/building for a few weeks. It's been blown off for 20 years, apparently. The other side is intact, but alot of the nails are loose. I've got all the rotted/busted wall studs, roof rafters, sill/top plates repaired/replaced. Now to get up and fix the roof. They left me some used steel roofing, so now I've got a lift reserved for tomorrow. They're calling for rain now. Figures...
   / Good morning!!!! #154,823
good luck gstrom, just don't fall.
102 was my setting before, am happy with that, maybe 103. None of those units are particularly accurate.
Intex has models that I really liked, but some issues with getting parts. Figured Coleman would be better with that.
yes to concerns over moisture. Need to keep it covered at all times when not used. I run a dehumidifier in basement all the time too, stays around 50%
I will watch that carefully.
   / Good morning!!!! #154,824
Good Morning
It was 68 and foggy when I got up, it’s sunny now and headed to low 80’s.
We got just shy of an inch of rain yesterday and overnight. Things already look greener.
Yesterday started with a muffin delivery from Drew, and I had to break the news to him that the dull bits were for wood and not able to be resharpened, at least not on my grinder. Rest of the day was spent doing chores and cleaning up.
Today I’ve got to go to Portland,ME after lunch. Looks like UPS just dropped off some parts, so I might get a quick fix done before getting cleaned up and heading out. Only good thing about the drive to the airport is that I go right past a HD in Philly, and they carry the charcoal that I like for the smoker, so I’ll stock up.
Drew, I’m with Ken, about the humidity being a problem putting the hot tub in the basement, not to mention the logistics of draining it.
   / Good morning!!!! #154,825
Drew - If your putting it in the basement and it's only for your use why not go for an inflatable bath tub?
linky
   / Good morning!!!! #154,826
BEF, sounds like a fun, but long trip. Glad you got some mountain time. Mabry's is a great spot.
It’s 1400 miles round trip if we don’t stray, so we did pretty good.
Glad we stopped at Mabry, youngest hadn’t been there for a long time, and it was a nice diversion from the interstate and rain. Wish I had time to drive further up the parkway.
Our first time at the Cumberland gap.
   / Good morning!!!! #154,827
linky
I could put an inflatable woman in it too!
I have a fully functioning heavy duty sump pump 10 feet away, fully tested, and with a tub cover on I don't expect much of a humidity problem.
If I do, I buy another dehumidifier. Cover will be on whenever not used which is almost all the time
spent an hour trimming shrubs, got a full load in golf cart, then plumber showed up. He's down lighting Havana cigars on my meter.
   / Good morning!!!! #154,828
bottom line on hot tub is I have a 1000 dollar solution instead of a 15K one, which would include a new door to the back yard and a new deck.
Not my house, can't do it. So I have to assume some downsides, and that may be another dehumidifier.
   / Good morning!!!! #154,829
What about a jacuzzi tub in your bathroom. Is this for social or therapeutic purposes?
   / Good morning!!!! #154,830
69°F and .46 inches rain. Overcast but only 11% chance Rain
So if it doesn’t rain I hope to get some seat time with the flail, but if it does then an inside day.
Prayers for all
Be safe
Have a great day
NEW Wolverine 72'' Skid Steer Sickle Bar Mower (A53002)
NEW Wolverine 72''...
Michelin CARGOXBIB High Floatation Tires (SET OF 6) (A52748)
Michelin CARGOXBIB...
VERMEER RTX 130 WALK BEHIND TRENCHER (A51242)
VERMEER RTX 130...
2016 TAKEUCHI TL8 SKID STEER (A51242)
2016 TAKEUCHI TL8...
2006 INGERSOLL RAND AIR COMPRESSOR (A52472)
2006 INGERSOLL...
(3) Air Hose Reels (A51573)
(3) Air Hose Reels...
