Good morning!!!!
   / Good morning!!!! #152,721
I wonder how many times most of us have turned on a pressure washer to clean off the wheels of the mower or tractor and
had the first blast come right back in your face with all the crud attached, because of the curve of the wheel? I never seem to learn.
I believe there is a safer way with OSHA rating. It involves a cone of water that makes sure nothing comes blasting backwards at operator.
You have the intense part in the center, but a covering wall of water around it.
Does anyone work somewhere where they have one of these safety powerwash nozzles?
time go out and water before it all droops.
   / Good morning!!!! #152,722
BEF - people request to join the R&RR group, then they get approved or denied, and once approved they are permitted to post. The posts are not individually "approved" as such, but the posts are monitored for appropriateness... unacceptable posts are deleted, and person might be blocked for a few days or banned after that.
that group has been going for 6 years now. there are 20 Admin / Moderators to share the load at this point. it's busy, but it's fun
   / Good morning!!!! #152,723
Drew,
Emptying the pump and leaving the impeller/pump sit dry is Simpson’s recommendation I believe.
Probably helps avoid corrosion.
   / Good morning!!!! #152,724
   / Good morning!!!! #152,725
Another great day at the beach will not leave till Sunday, this is our once a year vacation.
We sit on the beach alot just talking enjoying our time
Prayers for all Toppop Helogabals, Eric, all others silent or spoken our Country The USA
(y) :cool:
   / Good morning!!!! #152,726
that really is an amazing video
you can watch it three or four times and still laugh
and wonder how lucky those folks were
trying to stop sweating, a/c feels good, watered all the outdoor plants and garden, weeded veggie garden,
picked two more golden egg squash, hosed the pollen off the car and then sat on a chair near the garage with
good camera waiting for birds. Of course none came. Better I go out with cup of coffee early in morning.
potatoes starting to look sickly, all good. They dry out very quickly in those bags so I water every three or four days.
Tomatoes up to top of metal cages. Good thing those cages are strong.
   / Good morning!!!! #152,727
Thanks for PW comments, guys.
With my cheapy electric I have been guilty of turning on before the water flow ☹️. Usually because I just unplug instead of the less than reliable switch. Shouldn’t be a problem with the gasser. Have high hopes for this one. I had a Porter Cable with B&S engine 15+ years ago and was always a challenge to start, even after getting a new carburetor. Seemed the only reliable method was remove the plug and add gas directly. Sometimes I spent longer trying to start then actually using. Thinking this Honda will be much better.
   / Good morning!!!! #152,728
I wonder how many acres I'd need to fire off a bazooka?....... :rolleyes:
took several hundred photos today of all graves under tree limbs, where the drone can't get to.
Fun walk around, hot out there.
Lots of history here
had to report to house and grounds to stop procrastinating about this big tree and get it down before it crushes our stone wall around the graveyard.
Looking pretty precarious and long overdue.
Wonder if any little critters call tree home.
"I wonder how many acres I'd need to fire off a bazooka?....... :rolleyes:"
Last I knew in NH you need lic. to purchase TNT but not Tannerite,even our local gun shop sells it.
2019 clan way down the road :rolleyes: decided shoot of Tannerite instead of fireworks,it lot cheaper and bigger boom also left mess trees torn holes in the ground,police were call about the noise nothing they could do until after 10pm.
   / Good morning!!!! #152,729
66°F and .09 inches rain.
Get to inbox and play with new pressure washer this morning.
UPS dropped (literally) the new air fryer over the fence yesterday. I could tell as it was balanced against inside of gate at strange angle. I unpacked to check for obvious damage, none. There is a setup procedure involving a 20 min burn in and it was too late in the solar day for that. This morning.
Prayers for all
Be safe
Have a great day
Fedx Ground certain driver rather leave green slip in mailbox couldn't deliver etc. etc. will need to pickup,but the game cam show other wise when Mrs. show supervisor pictures...we both saw Fedx van make no attempt coming up the driveway,and were not the only ones.
   / Good morning!!!! #152,730
Wow!!! . . . And another reason to live in a "no kid" retirement neighborhood.
Most of those adults should have known better...yup couple french-fries short of happy meal.
Intermodel Metal Storage Crate (A51573)
Intermodel Metal...
2015 Ford Fusion S Sedan (A51694)
2015 Ford Fusion S...
2014 KOMATSU PC490 LC-10 CRAWLER EXCAVATOR (A52576)
2014 KOMATSU PC490...
2013 INTERNATIONAL 7500 SBA 6X4 DUMP TRUCK (A51406)
2013 INTERNATIONAL...
2004 Stage Line SL-250 Mobile Folding Stage Trailer (A50322)
2004 Stage Line...
2014 Peterbilt 384 T/A Day Cab Truck Tractor (A51692)
2014 Peterbilt 384...
