Good morning!!!!
   / Good morning!!!! #150,861
Good Morning.
67 and going up a little, cloudy with thunderstorms this afternoon. Sim passed through overnight, leaving about 7/10” of rain.
Yesterday was busy. Started by helping a buddy with a vintage Capris, which was actually a Fox Body Mustang with a Mercury badge. He replaced the entire AC system with an R134a system. Everything is new from the Condenser to the Evaporator, even the accumulator, compressor and all the lines. He needed to pressure test, evacuate, add oil and charge it with refrigerant. He did a great job with the install system was tight and evacuated to under 200 microns. When we were done, you could get the cabin as cold as you could stand.
While I had the AC tools out, next stop was another friend to see what was wrong with his house AC. Replaced the compressor run capacitor and it worked, but needed some refrigerant. Looked for leak without success, it wasn’t down much, so I’m not surprised I couldn’t find it.
Got home, changed a tire on the progressive mower, so hopefully it will be good for the season now. Did some weed whacking and a little work on the mailbox before calling it a day.
Today I’ll probably cut the bottom out of the mailbox and weld a stainless one in. I’ve got some paper work to wade through, but somehow that always seems to get put off.
Was it the early one with the Mustang rear window or the later bubble glass?
   / Good morning!!!! #150,862
others will disagree but if you don't have to run the engine flat out, as almost all commercial guys do, and your blades are reasonably sharp, if you can
back off the throttle 10 or 15 percent, you'll save a lot of gas
Need good engine speed for cooling air cooled engine, but not flat out.
I get a better cut at near WOT, even with new blades, but yes it sucks the fuel at higher RPM.
   / Good morning!!!! #150,863
speaking of ice cream, taking my elderly MIL here in a few hours.
Toppop, I had a Capri with the 2.8 V6 and automatic. Pretty car, nice saddle brown leather interior, complete dog.
Used to run it out to Summit Point raceway and watch the Vegas and Pintos screech around the turns.
   / Good morning!!!! #150,864
now I'm wondering if my "intelligent automatic" is so intelligent.
First three broccoli florets.
First pic seemed dark, and I had remembered to pop up flash. No flash. Seems too dark.
So....I turned the knob to A which I believe is aperture and lo and behold it flashed and a totally different picture.
Hmmm.
But which one is better?
I also noticed on the brighter pic it's only really focused on the front floret. While on the "intelligent" setting the focus is equal.
Lot to learn.
I've seen that lactaid brand, will try it. I really want to avoid the sugar, hard to do with questionable artificial sweeteners.
Bottom picture not as clear but more realistic.
   / Good morning!!!! #150,865
Good morning tractor people. It’s June 2 and still had to light a fire, in the hills south of Portland. No veggies in the ground yet👎🏻. It’s Friday junior!
   / Good morning!!!! #150,866
69°F and 0 rain
Nothing planned yet for the morning. That will change
H& F over at friends house this afternoon.
Prayers for all
Be safe
Have a great day
   / Good morning!!!! #150,867
Hmmm.
Lot to learn.
Drew, you found Depth of Field when you locked Aperture. Why only a small part is in focus.
Great for blurring backgrounds.
Aperture is the lens opening/closing. Speed would be my choice to increase the DOF and increase the light saturation in this scene.
Intelligent mode should have a spot focus mode, which would see the light level where you select the focus spot and would also fix this issue.
Lou -A1/A2 is Milk protein, Lactose is a sugar. I can't digest lactose at all.
Some people have a problem with too much lactose, I can't have any.
The proteins would be for milk allergy, so this sounds like it might be a solution for them.
   / Good morning!!!! #150,868
We just make our own ice cream. Ripe frozen bananas make a good base. Added vanilla beans make it a very good vanilla and adding coco makes for a good chocolate frozen desert. We also use frozen mango, frozen strawberries, frozen peaches, etc . . . No fatty oils or sugar is needed.
   / Good morning!!!! #150,869
67F, overcast, and wet @ 13:30. Calling for a high of around 71F for the day. Should start seeing some breaks in the clouds by around 17:00. Still some rain around in all directions, but none really close by.
Final rain total at the local weather station for yesterday ended up being 0.44" ... so close to half an inch. That will certainly keep things greened up and growing ... (y)
Woman just poked her head outside a bit ago and proclaimed "It's cold !" ... then headed out to weed the flower bed in back after locating Her tools ... in a pair of shorts and a short-sleeved shirt ... :LOL:
I'll need to start getting what She has gotten done mulched in the coming days, otherwise I'll be in trouble.
I'm guessing that it's probably too wet out to do much beyond what She is doing, so I'll be headed up to the shop to get back to working on the Kubota at some point.
Got a text from the local Kubota dealer yesterday saying that the front axle pivot bushing was in so probably run over there at some point.
Amazon delivery due in today - another 3 oil filters for the Cub, some pepper spray dog repellent for The Woman, and 5 more grow bags ... which will allow us to get the gladiolus and ranunculus bulbs planted.
Might see if I can get the frame on the Water Buffalo screwed together now that I have all the pieces.
Hope everyone has an enjoyable, productive, and safe Thursday ... (y)
   / Good morning!!!! #150,870
"Was told Dad fixed the electric wire, put a piece of barbed wire around it to hold it on."
I had to laugh. When I saw that picture I thought all he needs to do is cinch a couple of lenghts of wire around that tree and he will be back in business. Great minds think alike.:ROFLMAO:
Chris
I said it will keep the cows out of it.
19002 (A59231)
19002 (A59231)
2013 FREIGHTLINER CASCADIA (A58214)
2013 FREIGHTLINER...
2008 Ford F-250 Service Truck (A56858)
2008 Ford F-250...
2019 WANCO, INC LIGHT PLANT (A58216)
2019 WANCO, INC...
(1) HD 24ft Free Standing Corral Panel (A57453)
(1) HD 24ft Free...
7ft Workbench (A57453)
