Good morning!!!!
   / Good morning!!!! #139,771
Ron, those lights look nice. May have to investigate for mine.
   / Good morning!!!! #139,772
Glad you’re on the mend, Mike
   / Good morning!!!! #139,773
Took front of mule off and installed 4 LED lights in place of the very poor halogen headlights. Still need to add 2 relays to select between 2 and 4 lights. It can wait for awhile.
Why would you ever want to use just 2 lights when you have 4?
   / Good morning!!!! #139,776
Where is Rick? The Cha-Ching products, the wireless phone chargers decided they do not want to charge anymore. Does his have the same problem after about 9 mo. It is now a discontinue item on Amazon.
   / Good morning!!!! #139,777
Driving around the neighborhood you only need 2. I will use 4 when out on the trails. I was out with it this morning checking how well they. Neighbor was leaving for work. He was blinded by all 4 lights. Also 4 lights use a lot of amperage. Need to keep battery charged. Charging from engine is 22 amps.
   / Good morning!!!! #139,778
2021-10-14, 0341
60° right now...high about 70°...
Mowing is done....I'm guessing for the last time this year, but I could be wrong
Question for you guys since I'm writing about my mowing. I've always changed the engine oil at the beginning of the mowing season, but a buddy claims it's better to change before winter storage.
What's your opinions?
Margeaux chewed on on of my favorite winter slippers...well, I found it last night. I was pretty pissed and was probably too harsh with her. Damn...those slippers cost $35!
Well, finally worked out a schedule...stepdaughter has to work Wednesdays, Thursdays and weekends. I'll be at work Mondays, Tuesdays and Fridays, work from home Wednesdays and Thursdays. I expect some variations due to Doctor's appointments, but this should be a a fairly regular schedule until Suzette is ambulatory and can get around on her own
About month before mowers go into hibernation I change oil filters...looks like one mowing should be the last one.
   / Good morning!!!! #139,779
67F light sprinkle.
Been good day for outside puttering...ditches clean also 3 gray birch trees.
Feet up tonight and early to bed.
Enjoy your evening all.
   / Good morning!!!! #139,780
Dense fog this morning.
Went to a free RF fundamentals course put on by one of the big names in test instruments. Very good presentation and a good lunch provided.
2023 Kubota KX057-5 Compact Excavator with Angle Blade (A55314)
2023 Kubota...
Case Maxxum 140 (A50120)
Case Maxxum 140...
Plastic Bear Statue (A55853)
Plastic Bear...
2020 Toro Pro Sweep Vacuum (A55758)
2020 Toro Pro...
2015 Ford Taurus Sedan (A56859)
2015 Ford Taurus...
2017 Dodge Charger Sedan (A55853)
2017 Dodge Charger...
