Good morning!!!!
   / Good morning!!!! #137,201
74 going to 88.
Got a good hike in between the rain showers yesterday, but everything stayed too wet outside to do anything...and the humidity was so high it felt like I was trying to breathe underwater much of the day.
   / Good morning!!!! #137,202
Agree wingsprd way too humid
more rain and storms today becoming heavy later
Prayers for all
   / Good morning!!!! #137,203
good morning all
71 going up to low 80's today in overcast, showers and then thunderstorm
Looks like most of us on East Coast will get a good dunking from this storm system coming through.
quiet morning, then off to lunch with one of the school board members
grinder worked great, definitely the white/fine stone left the blades sharper than what I'm used to
my youngish helper stopped over to show me his new jet ski.
230hp, amazing. And they have a 300hp version too.
   / Good morning!!!! #137,204
Nice jet ski it’s amazing to see where they started to where they are now
   / Good morning!!!! #137,205
Thanks for the responses to my question as to why some are so opposed to AARP. I agree with what's been said, but of course, I reckon I'd be hard put to find anyone, or any organization, with which I agreed with ALL their opinions.
A new question. What would be a reasonable price to remove and haul off all the old rain gutters and downspouts from the house and replace them with 232 feet of new 6 inch gutters, 6 new downspouts, and 63 feet of the new gutter (across the front) covered with the screen you see advertised to keep leaves and such out of the gutter?
   / Good morning!!!! #137,206
Just under 2 amps is correct.
Thanks!
Did some checking yesterday, and all the outside lights I'd be replacing are controlled by in wall dimmer switches that are also HomeKit compatible. So whatever I get as a replacement needs to be dimmable. And when I tally the number of outside lights, there are ten of 'em. I think maybe 22,000 lumens x 10 would be a little much... :oops: :ROFLMAO:
So thanks also for getting me thinking about this project. Most of the existing light fixtures use the large screw in bulbs. And at least half of the bulbs have had the lens part fall off because the glue that holds them in place failed. In some, the motion sensor in the fixture doesn't work reliably, or at all. And none of them are all that bright even when they're working properly. Thinking now that a dimmable LED fixture (can't call 'em bulbs, and they'll probably have more than one LED, so what do you call 'em?) in the 5,000 to 10,000 lumen range that can somehow be mounted on the wall, probably via a blanking plate over the metal electrical box that's already there. Then use stand alone HomeKit compatible motion sensors to trigger them, which gives me logging of the trigger events, and tailoring of what lights come on when any particular motion sensor is triggered. I've already got it set up so that hitting any of the wall switches on that side of the house turns on all of the outside lights on that side, so it makes sense to do the same with the motion sensors.
   / Good morning!!!! #137,207
Good Morning!!!! 73F @ 5:00AM. Plenty of sunshine. High 93F. Winds S at 5 to 10 mph.
As expected, the Fire Weather Watch that is to start tonight has been elevated to a Red Flag Warning, and the PG&E PSPS has gone from Elevated to Watch. In past years we haven't seen this kind of weather until Labor Day, so like the fire season, it's starting early. Winds are supposed to be out of the north and northeast, which will blow the Dixie Fire back into itself in some areas, and push it into unburned areas in others. Unfortunately, it will probably overcome many of the fire lines that have been established, and fan embers in the interior of the fire back to life. All that new smoke will head down the canyon, so I see more days running the air filters and staying inside.
Bird, if you visit the AARP website, you can login to your account and stop most all of their emails. Like athletics, it's too bad they've politicized ageing in a partisan way, because dividing their numbers hinders their ability to lobby and advance the interests of those of us in their golden years.
It's OK if your diet doesn't have a label, Don. Have you noticed that once something gets a label, it starts to morph away from its origins?
Most all of the outdoor outlets had clear plastic covers on them when I bought the place, Don. A few were missing, most of the domes were yellowed and cracked. I've replaced most of them with the kind that has little metal doors you can open and shut to cover the outlets.
I can tell you what I paid for my gutters, Bird, but the price would be ten years old. I'm interested in how well RS's leaf guards work. Seems to me the designs I've seen would be as good at directing rainwater over the gutter mouth as they are the leaves.
Ron's photo today is a good reminder that hot air is best kept inside balloons where it belongs.
Did some tidying up inside the pump house yesterday morning, rerouting cables, trimming some of them, and putting a few things away. Didn't get around to rinsing off the solar panels, and with more ash and smoke on the way, I'll probably wait 'till the end of the week. Reviewed the comments in a thread I started last month in another forum on diagnosing the solar power system here, then ended up gathering information for a reply to the contractor's last unhelpful email. I'm pretty sure, Bruce, that I'm pretty much on my own with regard to the system at this point. If a year of complaints have been unaddressed, how likely is it that will change with another email?
   / Good morning!!!! #137,208
Good morning
It’s 68 and going up to 70 with intermittent rain.
Looks like I should have mowed yesterday, as it’s supposed to rain for the rest of the week.
Productive day in the shop yesterday, but I need to learn to clean up everyday, instead of in between projects.
Today will be a continuation of yesterday, I’m going to pick up some sheets of Baltic birch plywood, it will be interesting to see what the price is this week.
RNG- my outside lights are on Leviton WIFI switches for remote control, but are not dimmers. You can definitely get a 100w fixture that mounts in a 1/2” threaded hole in a box cover, but dimmable might be an issue.
   / Good morning!!!! #137,209
   / Good morning!!!! #137,210
I had the front gutters replaced with LeafFilter...60-70feet of gutter plus downspouts. Came to just under $2000.
There's a lot of negotiation you can do to get the price down since they'll highball you with the first estimate
Whatever you do, don't get those stupid mesh covers that clip in your existing gutters....they're useless
2018 INTERNATIONAL 4300 26FT NON CDL BOX TRUCK (A58017)
2018 INTERNATIONAL...
2011 Hyundai Sonata Sedan (A56859)
2011 Hyundai...
1990 TRAIL MASTER  TRANSPORT TRAILER (A58214)
1990 TRAIL MASTER...
2016 Ford Transit 250 Passenger Van (A55852)
2016 Ford Transit...
2006 International 4400DT466 (A57148)
2006 International...
SCREENER (A58216)
SCREENER (A58216)
