Good morning!!!!
/ Good morning!!!! #217,041
looks like a traditional rain maker headed North, sucking water out of the Gulf and sending
it north on a 45 degree angle
or so it appears
rain coming in at noon
going to leave car outside since it's not going to freeze and I'll take
any free car washing I can get with all the salt dust everywhere.
I turned my outside hose back on two days ago and did a quick wash on the car.
Really wanted to get salt off as much as possible.
I did remember to turn the outside water off in the basement, and take the nozzle off.
wrecked a few forgetting to do that.
But that old fashioned Goodyear black rubber garden hose has now been half buried and left outside for five years, and
seems to be just fine. Good stuff. Maybe being sentimental because Goodyear Rubber used to have a plant here locally in Trenton NJ. So it's gone through at least a dozen freeze thaw cycles and still seems ok.
As the guy on the tool testing show says
that's impressive
I would have thought some high tech plastic hose would last longer, but usually their cheap fittings fail.
there is only one outside spigot on this cottage so I have to improvise by running a hose around to rear of house.
only thing good about one spigot is it's better than none.
/ Good morning!!!! #217,042
30F partly cloudy day mid 30's for high,ice snow mix arriving around 7pm weather station showing up 2" :rolleyes: ending by daybreak tomorrow.
Pans for today...remove couple cement pads from walkway,first time ever ice push the pads up pads rock when step on bad tripping issue,not else plan might watch evening NFL playoff game.
Enjoy your day all.
/ Good morning!!!! #217,043
50 outside right now, the high for the day. Raining, or drizzling, grey outside.
Debating on getting the wood stove fired back up. An indoor day for us today. Too bad the playoffs don't start early.
Hope all have a great day and .....be safe.
/ Good morning!!!! #217,044
I wonder how many feet of antenna you need for ultra low frequency
so you can talk to the submarines.
now if you could eavesdrop on the whales...
Half wavelength is ideal for a simple wire antenna, which way down at their 76 Hz data comm frequency, would be 1225 miles in air.
One cool thing about sea water is that, despite it being very lossy (semi-conductive), it also has a very high dielectric constant (i.e. optical index), which really shrinks wavelengths by a good amount. I think most sea water has a dielectric constant around εr = 70, and wavelength shrinks by sqr(εr), so that'd bring ideal antenna length down from 1225 miles to "just" 146 miles. Those guys tow some long antennae, but probably nowhere near that long, so obviously their simple wire antenna is never going to be "ideal" at 76 Hz. 😀
There are antenna designs that can reach ideal match with much less length, but I imagine anything real complex would be difficult to deploy and retract underway, a simple wire seems preferable from the standpoint of just dangling it out there while cruising along. So I suspect they just deal with a shorter and very "non-ideal" antenna, by pushing way more power thru the transmitter than would normally be required with an ideal antenna.
It makes the transmitter design much more complicated and expensive, but the Navy has money. It also makes the transmitter and subsequent increased cooling requirements consume a lot more power, but they probably have cooling water and power to spare on today's nuclear sub's.
/ Good morning!!!! #217,046
76hz in music is low bass
apples and oranges?
Nope. Oranges and clementines. Basically the same idea, but in electric and magnetic field, rather than modulating air pressure via a speaker diaphragm.
In fact, the 76 Hz tone traveling thru your speaker wire from the amplifier to the speaker, is the same exact type of signal that's being pushed from a transmitter into an antenna. Ratio of voltage and current is a bit higher on antenna (higher impedance), and modulation of the signal is different (data versus musical attack/sustain/decay), but otherwise the same.
/ Good morning!!!! #217,047
good morning, 42 high of 48 and rain on the way
Did not need to fire up this morning but did it anyway, the wood heat feels so much better
Had a car hauled off that one of the kids had left on our property. It had been sitting there for years waiting to get the title
Cut another load of firewood and brought it over. Keeping the spare set of batteries charged. Need to look into file sharpener for the Makita 16 inch
GD was shocked that the school noticed her with, no pay no school. What we have been telling her all along.
Deciding to quit her winter break jobs and go on a cruise. We will help but she has to do her part and keep up the grades.
We will see if she learned a lesson
/ Good morning!!!! #217,048
Good morning TBN!!
59 this morning.
We are on the leading edge of the first wave. Second wave this afternoon during the Panthers game is supposed to be T'storms. They are concerned with lightning possibility.
Finally got the compressor up and running. Perfect in pretty much all ways right until the end putting it back. Hauled it to its shed with the tractor and got it set un the ground. Walking it the last few feet and it got away from me and went down. No damage except to me. Oil leaking out so I went to pick it up. Mistake! Felt it in my back right away so I'll be taking it easy. Shoulda lifted with my legs but I was in a hurry. Ended up getting it back up with the tractor. It sure is a lot more top heavy with the 2 stage pump on it. Got it in and ran it awhile to break it in. I'm happy with it. Leaks down enough to kick on @120psi after a little over an hour then takes less the a minute to get back to 160 psi. I have 7 "outlets plumbed in so leaks are expected. I'll be going through the shop today with soap spray and see if I can find any leaks. Probably the only thing that gets done as back is pretty painful!
Already had a second cup.
Everyone have a great and safe day!!
/ Good morning!!!! #217,049
Good Morning
39° with a high that might top 50 and rain is what we have to look forward to today.
In other words, not much will get accomplished outside today.
Yesterday actually followed the plan. Service call, lunch at Mission BBQ, Costco, etc.
I got a new 3D printing task, steering wheel hub cap for vintage Bolens tractors. I have the logo digitized, just waiting on dimensions.
Great show last night, Dale Watson is a great entertainer as well as a great musician.
He had a show at the Kennedy Center the night before, we are lucky to have a venue like the Sellersville Theater that attracts such great talent to a small (~300 seat) venue. There is not a bad seat in the house, and we had excellent ones at that.
Not sure what today will bring to keep me entertained, but I hope it’s inside…
/ Good morning!!!! #217,050
Local? We had three old Bolens tractors, two of them at the farm on Lurgan Rd. in New Hope, and a little garden tractor down in Morrisville. Always wondered what happened to those old machines, after they were sold.
There was also an old Oliver at Lurgan.
Me on the little Bolens:
/ Good morning!!!! #217,051
Good morning! 42˚F heading to the mid 50s with a N wind and clear skies. This cold front did not help our drought conditions out as the spotty rains missed us by 50 miles.
BIL one continues to improve and BIL two will soon have surgery followed by chemo treatments.
FireWise will be starting up again, holiday break is over. I ended up in 7th place in cards this quarter.
Tonight will be cold so the heater will be set to come on at 68˚. The house has stayed in the 70s this past week with the unseasonably warm temps.
/ Good morning!!!! #217,052
/ Good morning!!!! #217,054
Morning all, 40 going to 42 and rain.
In Europe they use 50hz and on fluorescent lights the flicker drives me nuts.
More Christmas decorations down, rain may slow the process.
Ron - tree on wires is so common here. Sorry you had so many things fry. We had outages yesterday on internet as down the street a tree was resting on the wires.
For subs we used a long cable hanging from a plane back in the late 80's. I would hope they have something better now.
We had to design for 400Hz for all our plane bound tech, I think either 28 or 48 volts.
Be well,
/ Good morning!!!! #217,055
Ron, sounds like you got a good electrical surge there. Any idea what caused it?
I'm surprised that modern building codes don't require some form of electrical suppression built in.
As in an easy to remove big MOV, like the disconnects on your outside a/c compressor.
of course a big surge will just blow through the MOV at times.
folks would bring in a lot of crazy burned up electronics to my Radio Shack, and I quickly learned it was worth
me handing out a free 3 dollar single receptacle surge protector with every new tv I sold.
And I got almost none of those tvs, computers or stereos back. Surge protectors work, except for the "big one".
With value of appliances and electronics in most homes these days, I think a whole house surge protector and several high quality surge protector strips are table stakes for pretty much everyone, but you are right, not yet code.
Good Tractor Morning Fuddy,
Tesla was so ahead of his time, what a fascinating man, absolutely brilliant, and smarter than Edison IMHO. 🙏
I completely agree. Have you ever seen his design for a check valve with no moving parts?
One of the transmitter antennas is over a large part of northern Wisconsin, so, yes huge. The submarine side designs were classified last time I looked, which I admit was some time ago. But yes, the towed sonar arrays can be very long. This paper quotes them as being up to over three and a half miles, so make your own estimates on the actual lengths.
https://princetel.com/wp-content/uploads/2023/12/towed_array.pdf
Whales have been monitored globally and individually for decades. Easy in the Pacific, harder in the North Atlantic, but important.
There are other ways to communicate with submarines that don't involve surfacing, and methods of tracking them that don't involve RF or sonar. All very Spy vs. Spy.
@kenmbz I'm with you on 50Hz flicker being a problem and at 60Hz some bulbs are "can't be in the same room" bothersome to me. Back in the day, there were some CRT monitors that were 60Hz +/- and I had to forage around to find one that was on the high end of the spectrum for me to use them. There's also a couple of cars (Cadillac?) That have a flicker in their brake/running lights that I can't be around as I find it so distracting. I can't imagine how bad it must be for athletes like baseball players who have really fast vision.
/ Good morning!!!! #217,056
local lawn mower place called C.A Magill's (near the current Magill's Hill sledding area)
growing up where we bought our Cub Cadets, and then wanting something bigger and heavier, graduated
up to a full size Bolens. That green and white paint sure was pretty but I don't remember it being particularly
super reliable due to belts. We graduated from the Bolens to a Gravely. Never wore that out.
Bolens larger models were really nice, they even did a small diesel model.
and then they were no longer, didn't make the jump to zero turns apparently
Their early diesels were made by Ducati under the Wisconsin name, but likely that had issues
so they switched to Iseki, a brand well known in tractors. I think those Iseki garden tractors would be a nice
collectors item
/ Good morning!!!! #217,057
Where's that? Magills owned the farm that was between two of the farms my family owned, spanning Lurgan Rd. up to Thompson Mill Rd., between Eagle and Street Road.
That 1050 in the photo was my grandfather's, but we all put plenty of hours on it. I also had a 1963 Cub Cadet 123, which was definitely more stout than the Bolens.
The two larger Bolens belonged to an aunt and uncle who ran a dairy farm (1692 - 1993), and I got to play on them as a kid, but never worked on them myself.
/ Good morning!!!! #217,058
Good Morning
46° and partly cloudy this morning. It within a degree or two of the high for the day already.
A large part of yesterday was spent in front of the computer. I completed my course, and used all of the waiting time learning how to model gears.
So some serious learning actually took place.
Got a call from the airport saying that there was a fire in the hangar and our Rubbermaid storage locker was destroyed and was the suspected starting point.
You can see the cart with the oxygen bottles had the wheels completely burnt off. About the only remains of the locker Is the aluminum doors, distorted and on the floor. The contents, mostly cleaning supplies, snack food, and a battery charger, polisher and a vacuum were pretty much consumed.
The regulator lenses were melted, but the bottles themselves survived
I got another call later stating that they reviewed surveillance footage, and our locker was a victim, not the instigator.
The apparent source was an extension cord plugged into an engine heater.
Zoe is intently watching squirrels, i think she might be thinking about climbing trees…
Today starts with dealing with another geriatric alpaca that died overnight. The vet was here yesterday, and gave him some medication, so it wasn’t a complete shock.
After that, maybe a Costco run, who knows what else will come up.
Wow, I'm glad that acetylene tank didn't blow. I looked that up and the heat can turn it to carbon and hydrogen and blow TFU! Pardon my French. Glad your cabinet wasn't the source. A former boss of mine owned a couple rows of boat storage sheds in Lago Vista Texas. Maybe 40 sheds? Anyway each had a 110 outlet, but one year there was a cold snap and all the engine block warmers and incandescent light bulbs used as heaters, threw the breaker and there were a bunch of inboards with cracked blocks. MTTS (moral to the story), drain your boat engine blocks people.
Congrats on the Fusion modeling. You are ahead of me. LOL. Our students have a power transmission/Cad class where they have to design a gear system including bevel gears, a housing frame and shafts. It gets 3D printed and they get graded in teams of 4.
When Zoe is done with the squirrels up there, bring her down here.
Not much more than a couple of sprinkles here either Don. Some places got some downpours albeit most were brief. We need rain.
Prayers for the BIL's. Tell your wifey Howdy.
Got up and cooked scrambled eggs, pan sausage and hash browns. Made me a big breakfast taco and I'm stuffed. Added some non alcoholic Irish creme to my coffee for a change. It was nice.
48F and windy, going to 56F. Son impatiently waiting for wind to die around dark to go play tennis.
SUPERCROSS SEASON STARTS 4pm Kalifornia time!!! A great series of weekly racing can be watched on Peacock channel for $10.99/month (plus it has movies and other stuff).
Contemplating a small electric job in my barn. I want to add a breaker and an outlet. I need to go get the breaker, I have the outlet and some armalite.
Billy and Arly, glad y'all can hike like that!
I read where playing tennis regularly can add 10 years to your life. I better get out there with my son!
Prayers for our team, Bupps and Holly, Ted and Dona, Don's BIL, our nation and for peace in the world.
Texas snow shoes:
/ Good morning!!!! #217,060
Low 50'sF now and high humidity but streets have dried up after the spotty showers yesterday. Looks like a nice day.
Probably do some work at the Old House. It's an ongoing project.
I'm really tired of people who like to get drunk on other people's money.
Have a great day everyone! Pray for our Nation!
2012 DIAMOND T TRAILER TRAILER (A58214)
2012 DIAMOND T...
Tandem Axle Rear Truck Frame (A59230)
Tandem Axle Rear...
2011 MULTIQUIP LIGHT PLANT/ FUEL TANK TRAILER (A58216)
2011 MULTIQUIP...
2023 NEW HOLLAND WAGON TONGUE AND LOADING CHUTE FOR NEW HOLLAND SQUARE BALERS (A55315)
2023 NEW HOLLAND...
1993 Ingersoll Rand 185 S/A Towable Air Compressor (A55973)
1993 Ingersoll...
2019 Jeep Grand Cherokee SUV (A59231)
2019 Jeep Grand...
