Good morning!!!!
   / Good morning!!!! #131,141
Welcome to GM Weld.man &Blacktruck. (y)
   / Good morning!!!! #131,143
I believe you have a fairly substantial puddle just down the hill as well, RNG.
I do, but that's the trouble: It's down the hill. As in about 1/4 mile and 200' down hill. Could probably paddle one of those plastic kayaks down slope, but I dunno about getting it back up! :ROFLMAO:
   / Good morning!!!! #131,144
Three solid days of manual labor. I'm going to try to push over the middle tree with the New Holland then .. a bit more lower limb removal on the other two trees.
Sounds like a good workout in the wood gym, Rick. Perfect for workin' off those holiday pounds and building some muscle tone. It's also a good way to wear out your favorite gloves, rip your shirts, scratch your face, dull a bunch of saw chains, and drop heavy stuff on your toes. DAMHIKT...:oops:🤣
   / Good morning!!!! #131,145
Good afternoon! 84˚F partly cloudy, South wind.
I had a call this morning that the front axel oil on the JD (4WD) was low and the tractor would be out of service. There was no oil showing on the short dipstick on the axel. I changed out the oil a month ago and filled it. I put a screwdriver in the dipstick hole today and determined it was right below the dip stick. There were no leaks. I added a half quart and that filled it up (it holds a gallon). I suspect there must have been a bubble in it or is just filled all the voids after being driving around. I did not check it after driving it when I changed out the oil because it has no filter to fill. Any other explanation?
   / Good morning!!!! #131,146
Good morning, low temp 36, high 59°F. Wind E 11 mph. Sunny!
Got some nasty news yesterday, the DIL has 3 months to live at most. They (the doctors) are guessing it is cancer. She is bleeding somewhere and they can't tell where. Guessing the small intestine, which normally (if you can call it that) is non operable. She has been in constant pain since 2006. She was on morphine until it made her physically sick even with gravol, so that was the end of that. Tylenol doesn't touch the pain, morphine makes her sick so they gave her something else. The doctors are a little reluctant to shell out Oxycontin.
A town run is in the cards for today.
Have a safe day all
L4N, i am so sorry to hear about your DIL. Special thoughts and prayers for her.
   / Good morning!!!! #131,147
Nope... takes a while to fill all those 'low spots' in the axle. When I had changed mine, did it nice and slow, took it up to the top of the fill hash marks and let it sit overnight. Checked in the morning.... a little lower, but still good. Used it a couple hours and miraculously was 1 1/2 quarts low.....filled it again and has been at the same full mark for the last 6 months.
   / Good morning!!!! #131,148
Often those bevel drive front axles when you drain them from the axle hubs and refill from the upper axle housing.
The spur and bevel housing doesn't have a high point vent and they will air lock in the upper portion of the hub,
after considerable time and some heating cycles the air will slowly dissipate from the housings.
   / Good morning!!!! #131,149
Rick, someone else from tbn just did a YouTube review of your cha ching. Do you get royalties from that?
   / Good morning!!!! #131,150
L4N so sorry about DIL prayers sent not fair how terminally ill are treated
nice finished product of pond PJS lots of patience paid off
2010 Blue Bird BB Conventional School Bus (A55852)
2010 Blue Bird BB...
205196 (A52706)
205196 (A52706)
2021 International HV507 4x4 12ft Single Axle Dump Truck (A55852)
2021 International...
2012 OVERLAN KILL TRAILER (A53843)
2012 OVERLAN KILL...
More info coming soon! (A55851)
More info coming...
