Good morning!!!!
   / Good morning!!!! #118,001
Well! Flooring is going great.View attachment 668280View attachment 668282View attachment 668281
1 room complete and hopefully the 2 smaller rooms today.
Air install still not right. Thermostat refuses to talk to unit. Several calls to Bosch and HP have resulted in no progress. This thermostat is needed in order to qualify for a substantial rebate, but not looking good for me.
Tech has been great as he was here all day sunday and most of the day yesterday. All free so far. Hopefully will be back today to finish.
Now that it is starting to get cold nights the oil burner has started with an issue. That tech is coming this afternoon.(will have 3 different companies here) I need to retire soon just to make the house available for repairs. LOL.
Hope everyone stays safe and healthy. Wish me luck on the repairs!
Flooring looks great.
I assume they have to cut all door frames to fit under.
Who checks which thermostat you have for a rebate?
Most thermostats basically the same, except some control more functions.
   / Good morning!!!! #118,002
Aunt and I are going site seeing today. No real plans. Just drive around the country side.
Finally got a picture of turkey and her chick. I am sure it is not my neighbors Guinea.
Best kind of day, take a drive and sight see without a plan.
   / Good morning!!!! #118,003
Good Morning!!!! 83F @ 6:15AM. Sunny. High 99F. Winds S at 5 to 10 mph.
Back into the 100s for the weekend, and most all of next week. At least the smoke is clearing a little more, but still not healthy breathing.
Pond looks nice, Paul, and what a relief. A post or two on Yelp! might help someone else avoid all that drama...
You can try starting out with a smallish tank, Ted, and just trade up to a larger one if you end up using it a lot. But if you're doing much TIG, you'll need pure argon for that, or helium if you're doing much thick aluminum. Then argon/25% CO2 for MIG and steel. So two bottles. I've worked my way up to the biggest bottles I can easily carry/lift into and out of the truck. Still not as big as we used to use at work.
That chick is growing up fast, Ron.
If I could figure out what size capacitor(s) to add to the A/C compressor, Ken, I'd be on it like a rooster on a June bug...
Monster watermellon, David. Be careful with that ibuprofen. Easy to get permanent acid reflux if you take it for too long or without food.
The county reported another 178 new CV19 cases over the weekend, bringing the total to well over 2000. The 18 - 24 age group now has nearly twice the population as the next largest, which is 25 - 34. And the only deaths are in the 65+ group. Yet somehow they're letting the barber shops open again, so I set up an appointment for next week.
Floor came out nice, Phil. Some thermostats need 5 wires, others 2 or 3. Depends on the furnace. Instructions should have come with the equipment/thermostat, and there shouldn't be any mystery to it if the person doing it can read...
I lost 20 pounds during my last move, David MFW. Took me most of a month, and almost 30 trips @ 3 hours each direction. What a way to start a retirement...
I wasn't getting ahead as I was trying to catch up this morning. You folks were posting as fast as I could read!:eek:
No nap yesterday afternoon; I didn't make it back from town until almost 2PM. Big flap at FedEx when they wouldn't ship anything in a beer box, and had to buy one of theirs and repackage the valve set. What a mess. But the hydraulic shop had the correct fitting for the tractor, and I scored five pounds of Hatch chilies at Safeway.:thumbsup::thumbsup::thumbsup::cool2: So I'll start the day roasting chilies before it gets too hot out. Ended up with a BenQ monitor, with an extended warranty. Should be here Friday.
Got a loose connection on the Vanagon's tach fixed before the trip, but now there's an intermittent alternator light on the dash. I can tell from my voltmeter that he alternator's working just fine, and the blinking seems more vibration/RPM related. I see some wire chasing in my near future...
   / Good morning!!!! #118,004
Why not drill and tap the bottom and install a plug? Then you can change it regularly.
As soon as it’s fixed, I’m selling it , or giving to my dad.
It runs ok while cold. A dishonest person would have sold it as is.
You still have to take transmission off to fill it, no external reservoir like my old wheel horse, and you won’t get the plug out while it’s on the tractor.
These things are not made to be serviced.
   / Good morning!!!! #118,005
Of why not just use a little manual suction pump, as I've done? In fact, I guess I still have that little pump.
   / Good morning!!!! #118,006
Understood.
   / Good morning!!!! #118,007
Good morning to all! Low of 50, only going for a high temp of 76 today! Woohoo! Chances of a shower this afternoon. Low tonight now forecasted for 44. All of this will be short lived.... temps back to the 90's by the weekend.
PJ, HAPPY ANNIVERSARY! Enjoy your dinner together! Oh, nice pond, they did a great job.
Ron, nice turkey pic, I would think the chick would be bigger by now....
Drew, thanks for posting the tractor video. Looks like there is a good air ride setup in the cab. At first it is strange to see the 3 point setup in front, but then remember that most European tractors are made that way. I can understand the reason for it, but do they have to plow in reverse?
Randy, I have never had gas hooked up to my mig / wire feed also. Only used the flux core wire. It is said that using gas, Mig welding is much cleaner and easier. For TIG welding, it is a requirement to use gas...
Ken, were you able to find the leak?
Some errands again today, one to get a couple of 220v 50amp plugs to make a heavy extension cord for the welders. Then maybe finish pulling the additional 220 circuit in the shop, got started last week, but never finished it.
Everyone have a great day!
   / Good morning!!!! #118,008
The oil in it was just replaced 2 yrs ago. It looks good and clean. I have one of those suction things, never used it.
The real solution is what Don said, buy one that has a drain to start with.
This was not an entry level husqvarna from a box store, but a “better” model with a welded deck from a mower dealer. Yet it still had the same basic entry level transmission. Live and learn. I got over 10 yrs from it and with rebuilt transmission should go for 10 more. Does need new battery. Also needs a safety switch replaced, just not sure yet which one. I jumpered across a couple to “fix” that issue.
   / Good morning!!!! #118,009
Good afternoon, the weather is gorgeous here, with just a few fluffy clouds and a temperature that was perfect for wandering around a nearby town this morning in just shirt sleeves. First time we have been inside a shop together in many months.
Kyle, I have quite a strong Yorkshire accent, which is no problem in the North of England but a rare thing where I now live. Thanks to films and tv shows, the locals around these parts will have far more experience of hearing a wide variety of American accents than mine, so it may actually be quicker if you order the beers while I just smile at the barmaid and pass over my credit card - plastic is a wonderful universal translator.
PJ, great to see the major landscaping reach completion and congrats on your 17/7. I would be hoping the lead time on the neighbor's Chevy was long enough to be in with a chance of a second helping of peach crumble :licking:
About 5-6 weeks ago, I think I wrote about finding a lady's wallet ....... got a card and a very sweet thank you note from her yesterday
Roy, you would never guess it if you only read the news headlines, but this world has lots of very good people, just like that lady - and you.
   / Good morning!!!! #118,010
Thanks, and yeah, we've planned to write a few reviews here and there. We just wanted to wait until the whole thing was done. You know, not jinx ourselves. We'll probably sit down this weekend and gather all the details, then start writing.
He did great work for us when he built the new retaining walls around our walkout basement. Then, the next smaller project didn't go as well. The pond, of course, was a complete disaster. Whenever The Wife would chat with him either on the phone or via text messaging, he always assured her that we were at the top of the list on his white board. She popped into his office one day after not hearing from him for awhile, and discovered that not only were we not at the top of the list, we weren't on the board at all. That was the proverbial straw, when it was obvious he had no intentions of finishing it. I won't feel at all bad about writing an honest review of our experiences with him.
2014 Ram 4500 Chassis Versalift Bucket Truck (A52377)
2014 Ram 4500...
2020 Kia Soul SUV (A52377)
2020 Kia Soul SUV...
2014 INTERNATIONAL 7400 SBA 42 LUBE TRUCK (A51406)
2014 INTERNATIONAL...
2012 Ford F-450 Altec AT200A 30ft Bucket Truck (A51692)
2012 Ford F-450...
2017 GRAND DESIGN RECREATIONAL MOMENTUM (A53843)
2017 GRAND DESIGN...
2004 Kia Optima Sedan (A51694)
2004 Kia Optima...
