Good morning!!!!
   / Good morning!!!! #109,331
Good Morning!!!! 48F @ 5:00AM. Some clouds this morning will give way to generally sunny skies for the afternoon. High 66F. Winds WNW at 10 to 15 mph.
I think I'd be more curious about where all that water went to, and be looking for the exit of the drain on the other side of the tracks, Eric. Maybe use of a long plumber's snake a few times a year would keep the opening open?
I'm jealous of your Walmart experience, Wng. Got through to my neighbor that drives delivery trucks for Walmart, and I'm told most stores that were getting two truck deliveries a day are now only getting one delivery every two days. Yet he's working more than eight hour shifts, and six days a week. That's in California and Nevada, and helps explain the bare shelves that I'm hearing about here.
I got curious about the census last week and filled out my questionnaire online. Then got a letter from them yesterday saying someone will try to visit (but they'll run into a locked gate unless they notify me first) AND they'll send me another questionnaire. No wonder they're hiring all those census takers with all that duplicated effort.:confused3::mischievous:
Hope you get some good news at the doctor's office this afternoon, Drew. You're more than past due for some.:thumbsup:
Something's not adding up with the CoVid-19 news, Ron. The geometric progression expansion of the disease seems to be holding up in California and nationwide, and medical staff at those NYC hospitals on 60 Minutes the other night looked exhausted. Yet someone has time to make that very fancy and time consuming dry erase board? Doesn't make sense. :confused2: But I'm with you with regard to staying home as long as possible, riding out the peak with as close to zero exposure as possible.
I'm hoping for some good news this month, too, Thomas. And that's no April Fool's joke.
The hummers got through two gallons of nectar in three days, and were trying to land on the refreshed feeders as I hung them yesterday. And twice now I've seen a very aggressive male attack another bird in midair and drag it down to the ground for a series of pecks. Once last night landing right next to me while I was on the phone with one of my buddies.:shocked:
The 3/8" x 2" steel bar for the propane tank hold downs showed up yesterday, so after cutting and drilling it, I set the wedge anchors in the concrete pads. Screwed up on the first hole, putting it 90ー from where it needed to be, and thought I'd be able to pull it out with a 4' pry bar. Uh uh, it just mangled the washer I was prying against. So I ended up cutting it off with a zip blade in the angle grinder, then tapping the stub back down into the hole with a punch. I had some concrete patch left over from another job, and used it to fill the hole. But now I wonder why there seems to be so much vertical slack in the studs, nearly 3/4 of an inch. Maybe I'm doing something wrong?
The shop manual for the Kubota has a very nice write-up on the hydraulic system that powers the tractor, describing fluid flow through each of the many components in each of several operating modes. Took a while to get through, but the take away is that there is a pressure regulator that governs overall system pressure, and there are several over pressure gates in the system, any one of which could cause the lack of power situation I'd seen the day before. I also found where the pressure test ports are located, but learned that a special adapter would be needed to hook up a gauge. Not wanting to get too deep into it right off the bat, I decided to take another ride and see if I could duplicate the lack of power problem. I'd been putting it off all day because problems seldom fix themselves, but I also didn't have much info to go on and didn't have much to lose in taking a five minute ride. The tractor fired right up, seemed to run fine, and the bucket loaded with gravel without any hesitation. Wheeled it over to the base of the hill, shifted to low range, and it went right up with no hesitation. Dump, back drag to level out the gravel, back down for another load. No issues. Kept going, hoping I'd either finish spreading out the gravel, or the problem would come back. The only time anything came up was one trip where I forgot to shift into low range and the tractor stopped as it swung directly up hill, making the same kind of stressed noises from the hydraulic system it did the other day. But it's hard for me to believe that such a simple mistake would be the solution because I'm forgetful enough to not be in the right range and it's second nature to hit the paddle switch if something like that happens. And as more time elapsed, the tractor's response to the go pedal, even in low range, got more reluctant, especially heading directly uphill. So my guess at this point is that it's something time, and probably heat, related. The shop manual mentioned a clogged hydrostatic filter as a possible cause, but there's less than 40 hours on the filter and oil. It also said that using the wrong hydraulic fluid would cause problems. I'm using the Tractor Supply version of Kubota's UDT fluid, which they say is equivalent, but maybe at high temperature it somehow doesn't do the job as it should. It's not very often that I run the tractor that hard for as long as I did the other day, so if that is the issue it's no surprise it didn't show up until now. The grass is starting to grow pretty vigorously, so I guess I'll find out in a couple of weeks when I start mowing.
Meanwhile, I did finish the gravel spreading, at least the part under where the solar panels will go, and enough to let me get started building the rack. Here's a look:
You know what day it is, right?
It's hUMp Day!!!:laughing:
   / Good morning!!!! #109,332
Interesting read Frank thanks for sharing
   / Good morning!!!! #109,333
47 degrees this morning, going for a mostly cloudy 73. The yard needs mowing, but it's still wet and more rain forecast for tomorrow. I thought that I didn't have anything to do today, but this morning the overhead light was flickering and going partially on and off in the kitchen. I'm getting to an age that I hate to get on ladders, step stools, etc. but I got up there and found one of the three tubes was dead. Fortunately, I had some spares out in the shop and replaced that one.
   / Good morning!!!! #109,334
RNG, how much gravel is that? I moved 10 tons over the summer, but this looks like my run was a drop in the bucket!
Happy April 1st all.
   / Good morning!!!! #109,336
Virginia is now doing over 1,000 tests per day. 90% have come back negative for CV. So lots of the sick people here do not have CV.
I saw on the news last night that Abbot Labs has come up with a new test for CoVid-19 that gives results in only five minutes. The turn around for the current test is four days. If they can mass produce enough of them, doctors will know who to quarantine, and will be much more liberal with the testing so they can sequester disease vectors earlier and limit the spread. Could be a huge game changer. Too bad I sold my Abbott Labs stock when they split the company last year.:banghead:
   / Good morning!!!! #109,337
Received this link from a friend yesterday. Interesting reading ...
Restrictions Are Slowing Coronavirus Infections, New Data Suggest
Frank
That's some good news indeed, Frank, and we could all use a little ray of sunshine right about now.
But the story also contained this troubling quote:
"On Sunday, Washington state also reported a downward trend following the imposition of its restrictions, based on data from deaths, coronavirus tests and information about people痴 movements from the Facebook apps on their cellphones."
Facebook has long been accused of abusing people's privacy, especially with its cellphone app. I wonder how many of those phone owners know that their movements are being tracked by Facebook? I refuse to load their app onto my phone, and instead use a web browser to access Facebook when I'm out on the go.
   / Good morning!!!! #109,338
That was about 4/5 of two tandem truck loads of gravel. 40 tons if the scale paperwork I got from the trucker was correct. 1 cu. yd. of road base weighs 1.5 ton or 3000 lbs. => 16 cu yd./trip. But weight doesn't necessarily correlate with volume; it also depends on how much water is in the gravel. Storms were forecast for the week following that delivery, and I had to beg the trucking outfit to work it into their schedule. I think I was charged accordingly, though, as the price I paid was up over 50% from similar deliveries eight years ago.
   / Good morning!!!! #109,339
Easier than typing!
I’ve found myself in Afib this morning, had a couple of incidents since switching BP meds. Lowered my BP but might to regulate my rhythm with something else, anyway I gotta go to the cardiologist tomorrow.
It’s so cool, windy and damp that I’m not sure what I’ll get into today.
Everyone please stay safe!
   / Good morning!!!! #109,340
A mixed sun/clouds 28ºF for today's low temperature; a mostly sunny 37º presently; and I anticipate a mostly sunny afternoon with high temperatures in the high 40ºF's.
I woke up this morning ~2:00AM with a leg cramp and that was it for sleeping today. I started walking around and I could not see correctly everything was out of focus like I was having a neurologic/optic "event" :eek: which was "somewhat" disconcerting and then I checked- I was wearing Wifey's glasses. Her vision is almost as bad as mine.
Eric- Good luck with the mucking. I've seen a a couple of quicksand specials over the years; don't squirm and you will not end up with a hand sticking out of the mud.
RonJH- I really like cardinals. The resident pair here nest in one of my forsythia bushes. I love the signage. We are all in this C-19 challenge together or should be.
Frank- Thanks for the link. A lot of evidence is supporting restrictions, maintaining interpersonal distances, OCD hand washing and cleaning, and using å¡«niversal Precautions.
Randy- Take care and good luck.
Ted- My + thoughts, wishes and prayers on hyperdrive for your Daughter, you, and family.
It's a beautiful day here to appreciate the outdoors, life, and thankful that at least for now everyone with whom I interact, like, and love are still and hopefully will remain free of C-19.
My + thoughts, wishes, and prayers.
2014 SKYTRAK 10054 TELEHANDLER (A58216)
2014 SKYTRAK 10054...
3PT BOOM POLE (A58374)
1612 (A58375)
1612 (A58375)
LOT: Cutters, Shears, Giant Chalk Line, 100' Tape Measure (A59076)
LOT: Cutters...
2015 RAM 5500 Bucket Truck w/ Versalift SST40 boom -Cummins Diesel - Auto Trans- 4X4 - 72096 miles (A55302)
2015 RAM 5500...
ROLLING METAL RANK & CONTENTS (A58374)
ROLLING METAL RANK...
