Good morning!!!!
   / Good morning!!!! #106,081
Wife woke me up at 3:30am after hearing a scream outside near our window...Coco barked, too. She said it sounded like a lady screaming multiple times. Of course it was silent once I got up. I'll look for bodies after it gets light, but no one lives nearby, and we're back too far from the road, so thinking it was wildlife. Maybe a fox, coyote, bobcat or owl. But she was sure spooked.
That sounds like a Fisher Cat to me. They do scream like a woman.
   / Good morning!!!! #106,082
Drew, do you harvest / capture any rainwater to use in the greenhouse? Do you start your seeds in local soil or do you use the peat cubes?
I think I use about a gallon a day to water the greenhouse in early temps, later when hotter maybe a little more.
The answer is no, my greenhouse is awfully tiny though the garden shed next to it could use a rainbarrel on the corner.
Which would mean putting gutters on it. I use a professional propagation mix which is ground very fine, in addition to some Burpee seed starting mix.
This year doing just flowers and no veggies is much easier. I over seed the tray, and then transplant when large enough by breaking the tray apart in small pieces. Later on, close to middle of April, will start direct seeding, all of this going into prior veggie garden. There I have water piped out to garden and can run sprinklers in dry weather. That garden is mostly covered in black plastic with one big open area.
Thankfully local municipal water rates seem reasonable. .09 cents per gallon.
I have no doubt your results will be gorgeous.
I also suspect your bounty will be sorely missed this year.
   / Good morning!!!! #106,084
LS, I keep getting drawn to the cedar grove area.
When you glue panels do you biscuit them?
Yes, you are correct to the Cedar Grove area.... was my hint to easy?
If I am doing larger boards (+4-5 inches), I will usually biscuit join them, especially for tops. The top for the drop leaf table was tongue and groove. This next project (two end tables) is being made from a bunch of leftover 2 inch white oak tongue and groove that either had bad tongues or bad grooves. I am ripping them through the table saw for uniform width (taking off the bad spots) (both T&G). Makes them about 1 5/8 wide. Just gluing the edges/ ends together. Once dry, I cross cut for square and run them through the planer.
   / Good morning!!!! #106,085
I am sure the food pantry folks are going to miss your contributions! With that in mind, you need to take care of you first. We will be transplanting a bunch of small pines and bushes that have overgrown their current containers this spring. I was going to do a 50/50 mix of the natural soil and potting mix to get them used to the soil for planting the following spring.
   / Good morning!!!! #106,087
32 and foggy...rain ended and heading to 50.
Nice looking church, Kyle.
Well, did as planned yesterday...roasted coffee (use the metric system for weights and temps) and worked on taxes...used inches if I wanted to measure the stack of papers :).
Metric taxes....that would be tough. :)
Hope you don't find a body.
I'll bet your coffee is great!
Good Morning!!!! 50F @ 5:00AM. A mix of clouds and sun. High 66F. Winds light and variable.
All this talk of weights and water has me hoping no one drowns anytime soon. And Eric, my bodyshop neighbor is a nice guy, but he's also the one that almost cut his leg off with a chainsaw last year. Not sure I'd trust him with that loader joystick.:laughing:
Thanks for the photos, Ron. The cardinal is another bird I miss, and not just their bright red feathers. The song, too.
My money would be on a fox, too, Wng. First time I heard one here was dawn on a summer morning with the sliding glass door open in the master bedroom. Sounded like what I'd imagined a mountain lion scream would sound like, sent the hairs on the back of my neck standing straight up. Sprang out of bed, pistol in hand, and peeked out the door only to see a little gray fox standing 20' away. If a fox can laugh, that one was all but rolling on the ground.:laughing:
We got the holes augered for the solar array yesterday, and if there's such a thing as the perfect tool for the job, that big backhoe was it. We hit rock several times, and that heavy auger point combined with the down force from the hoe just chewed right through them. :thumbsup: But we almost didn't even get started; the extension I'd rented was so beat up it wouldn't fit on either the auger or his drive motor. I had to grind off heavy burs in the hex socket and shaft, wasting his time and my money. The rental was sorry about that, and refunded the rental fee, but my buddy was being paid by the hour to watch me run the grinder and belt sander.
The rails for the solar array showed up right on time, and the driver even helped me get 'em into the shipping container. And the pine in the little pallets the package came on split into some nice kindling while I was waiting on FedEx to show up with the generator. But they never made it, and a call to them revealed it hadn't even been loaded on a truck yesterday. I could'a been cleaning up the dirt around the auger holes, but I didn't want to swap the forks for the bucket on the FEL in case the tractor was needed to unload the generator.:irked:
I did get the van washed, and drove it to return the auger extension, so it's all ready to go camping today. It's our annual No Football campout down in the Sacramento River delta. And as usual, the forecast calls for fog, "heavy at times". But no soggy tent in the morning this time; I'm sleeping on the floor in the van.:D
Hope everyone has a great weekend!
Faulty/crappy rental equipment. Arghh. Hate those backward steps impeding progress. Once rented a 3 point tiller. The top link holes were so elongated, that they allowed to POS to just bounce up and down instead of cut. Wouldn't give me my money back. Never went back. They went out of business. Shame, because they were so close to me.
Good morning! 37˚F, a dusting of frost and clear skies heading to the high 60s.
Kyle the two best features of that church are the original bell in the tower and the pipe organ. When the bass is played the floor vibrates.
Kyle one of my distant relatives made your local paper when he started a brush fire (probably with gasoline) and severely burned himself. They are looking to amputate his leg.
Ron, thanks for the link to Harvey's thread. He does take on huge projects. Of course without him I would have never thought about building my grange/workshop.
Time to head to the garden and make a fuel run for all the equipment. We will have the big spring clean-up in two weeks.
Wng, I'll put my money on the scream of an owl.
Hope your relative can keep his leg. Hard to imagine how his leg got that badly burned, unless he was trying to put out the fire regardless of his leg.
All, the church is Don's church. I think it is very nice looking.
Got plenty o' chores to do today. Weather is nice.
   / Good morning!!!! #106,088
Got my taxes done after spending 1 hour on phone with TurboTax. Seems that their software does not properly transfer data to Michigan state tax form if you are a senior born before 1946. Then when I tried to use their online help they wanted $50 for that. Phone call wanted same thing until I called another help number from past years. It’s done and I am getting more back than last year.
In Michigan if you are born before 1946. You are grandfathered into not having to pay income tax to the state.
   / Good morning!!!! #106,089
B O N U S !!
   / Good morning!!!! #106,090
toppop; yer right. I just looked it up and the only areas so far, that far South is 4 counties in North West Virginia, in the big hills.
2018 Kia Optima Sedan (A56859)
2018 Kia Optima...
2022 Takeuchi TB 260 Excavator (A59213)
2022 Takeuchi TB...
2025 CFG Industrial QK18R Mini Excavator (A59228)
2025 CFG...
2021 UTILITY VS2DX 53FT DRY VAN (A59575)
2021 UTILITY VS2DX...
2004 John Deere 120C Excavator (A59213)
2004 John Deere...
MMS MS36C Skid Steer (A57149)
MMS MS36C Skid...
