Good Loaders for TC 35D ?
   / Good Loaders for TC 35D ? #11
Probably referring to the aftermarket cable operated loader control valve used on the aftermarket loader. A generic installation so you don't have to buy the NH two spool fender mounted loader control valve. Get the NH loader valve regardless of what loader you end up with. Cable control valves are prone to taking on water between the cable and sheath, then freezing.
   / Good Loaders for TC 35D ? #12
I got the 16LA for mine as a package from the dealer when I bought the tractor. It has been great - no problems, lifts pretty much anything I ask. (Except when I had the pallet forks on and loaded it up with too many railroad ties - too far out on the forks, too. I think I had about 12 or 15 - It just sat and groaned and didn't lift at all).
If you get the 16LA, think about springing for the Quick-Attach - it is FANTANSTIC - takes me less than a minute to swap between pallet forks and bucket. Throw two levers, climb on and back away from the bucket, drive up to the forks, climb down and throw the levers back. Too easy! /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
Doug
2003 STERLING LT9500 SERIES DAYCAB (A58214)
2003 STERLING...
Bobcat S740 (A57148)
2020 FREIGHTLINER CASCADIA 126 TANDEM AXLE MID ROOF (A59575)
2020 FREIGHTLINER...
New/Unused CFG Industrial MH12RX Mini Excavator (A57453)
New/Unused CFG...
MARATHON 20KW GENERATOR (A55745)
MARATHON 20KW...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A56860)
2025 Kivel 48in...
