Good JD - to - skid steer adapter?
   / Good JD - to - skid steer adapter?
You do know that you can get a JDQA grapple from several manufacturers?
Hi Musdalen,
Yeah, I was aware that there are a couple manufacturers that make JDQA grapples, but I just really like the idea of having the whole wide world of SSQA implement variety available to me... maybe I just need to get over it. :)
   / Good JD - to - skid steer adapter? #23
Hi Musdalen,
Just pay attention to the weight of the attachment itself. You don't need one capable of lifting 2 tons...the extra mass of the attachment comes right out of your payload budget.
   / Good JD - to - skid steer adapter? #24
Hi Musdalen,
I thought about that too. Esp. with regards to the used implement market. But then I decided there just aren't that many things I need or even want, and on those few implements (bucket, grapple - maybe someday - forks), I wasn't willing to settle for mismatched gear for my tractor. Besides, it is doubtful it would probably never pay for the price of the adapter anyway.
Hah, yeah, when the FEL can only lift 1200lbs "paying" for the weight of a 4000-lb capacity plate doesn't really make sense. :p
In addition to the added weight coming out of the FEL capacity, there is also the issue that the adapter plate moves the load further out away from the tractor body, further decreasing the effective capacity of the FEL.
   / Good JD - to - skid steer adapter? #26
Exactly. Another thing I like with the JD QA setup is the simplicity. There really isn't anything to get rusty and seize up even if it is neglected for years.
Fair enough. Thanks for the feedback everybody. Looks like I'll just stick with the JDQA, get whatever implements I can with that, and if there's any I desperately need that I can't get with JDQA I'll weld on an adapter plate.
Many thanks.
Bush Hog 3pt 14' Mower (A53317)
Bush Hog 3pt 14'...
2007 Tymco 500X Air Sweeper, Turbo Diesel, 3876 Hours Indicated, mounted on 2007 International 4200 (A59076)
2007 Tymco 500X...
2019 International HX620 T/A Wet Kit Day Cab Truck Tractor (A55973)
2019 International...
flooring (A55758)
flooring (A55758)
2020 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A56858)
2020 Chevrolet...
LOT: Steel Work Table 36" x 72" w/8" Craftsman Grinder, (2) Lockers (VISE NOT INCLUDED) (A59076)
LOT: Steel Work...
