Good JD - to - skid steer adapter?
   / Good JD - to - skid steer adapter?
You do know that you can get a JDQA grapple from several manufacturers?
Hi Musdalen,
Yeah, I was aware that there are a couple manufacturers that make JDQA grapples, but I just really like the idea of having the whole wide world of SSQA implement variety available to me... maybe I just need to get over it. :)
   / Good JD - to - skid steer adapter? #23
Hi Musdalen,
Just pay attention to the weight of the attachment itself. You don't need one capable of lifting 2 tons...the extra mass of the attachment comes right out of your payload budget.
   / Good JD - to - skid steer adapter? #24
Hi Musdalen,
I thought about that too. Esp. with regards to the used implement market. But then I decided there just aren't that many things I need or even want, and on those few implements (bucket, grapple - maybe someday - forks), I wasn't willing to settle for mismatched gear for my tractor. Besides, it is doubtful it would probably never pay for the price of the adapter anyway.
Hah, yeah, when the FEL can only lift 1200lbs "paying" for the weight of a 4000-lb capacity plate doesn't really make sense. :p
In addition to the added weight coming out of the FEL capacity, there is also the issue that the adapter plate moves the load further out away from the tractor body, further decreasing the effective capacity of the FEL.
   / Good JD - to - skid steer adapter? #26
Exactly. Another thing I like with the JD QA setup is the simplicity. There really isn't anything to get rusty and seize up even if it is neglected for years.
Fair enough. Thanks for the feedback everybody. Looks like I'll just stick with the JDQA, get whatever implements I can with that, and if there's any I desperately need that I can't get with JDQA I'll weld on an adapter plate.
Many thanks.
toro reel master (A56857)
toro reel master...
2015 Peterbilt 348 S/A VacCon Combination Sewer Jetter Vacuum Truck (A55973)
2015 Peterbilt 348...
1998 Volvo VN T/A Dump Truck (A56858)
1998 Volvo VN T/A...
MURRAY PUSH MOWER (A55745)
MURRAY PUSH MOWER...
2006 Utility Trailer MFD. T/A 32FT Dry Van Trailer (A56858)
2006 Utility...
LOT: Fuel Transfer Tank, Tool Box, 12 Volt Fill-Rite Pump (A59076)
LOT: Fuel Transfer...
