Good grease gun needed!
/ Good grease gun needed! #21
When adjusting the front idler on a doze, you pump in grease. It must have high pressure. I have 2 good level guns from John Deere. I am sure that they are no better than most of the good ones, and were not any more expense. I use my Dewalt electric most of the time with lock-n-lube. It works great and save me a lot of time. As I get older, I like things easier.
/ Good grease gun needed! #22
I'm looking at 7K to 10K PSI guns. I'm not sure what the Atwoods, TSC, WalMart guns are rated at but, they are basically a waste of money for anything other than pulleys in my lawnmower deck. They leak grease and are generally a terrible mess to use.
The LockNLube and Lincoln lever guns are looking good at a 'moderate' cost.
Is this for mainly hitting zirks on a tractor? I got a Lincoln 1162, pneumatic, got it on Amazon for around $70, I have a lock n lube on it. It's worked great for me.
For my personal use, it is mainly the tractor loader zerks and few on the tractor steering components. For the lawnmower, a simple pistol grip unit works fine.
When I borrow my friend's track loader, it'll get used there too.
/ Good grease gun needed! #24
I'm pretty sure I've never owned a lever rigid connector grease gun. I'd be curious what uses would require that?
I use a Dewalt 18V. Have one pistol grip hose gun with a needle fitting hanging on the wall for those couple times a year use. Otherwise it's the Dewalt. I use 30-40 tubes a year.
A pistol grip hose grease gun is GREAT for a lawnmower deck and low-pressure fittings in various places.
The rigid neck lever grease guns are really nice on things like disc gangs and hard to reach fittings where you can't really use your hand to place a hose fitting. The rigid lever grease guns are also really good for hard to fill zerks (within reason).
The battery-operated model my friend has works well for him and his track hoe because he needs a lot of grease capacity and has some tough zerks that need high pressure. I find it to be a bit bulky and unwieldy and prefer a good rigid lever gun but, it's not like I'm running 3 or more tubes a day through it either, more like one a week. ;)
/ Good grease gun needed! #26
With a LockNLube you can put a hose on a lever gun.
Started short:
Went 4' long:
The advantage is that I can lock on the zerk, put the gun on my chest, both hands on the lever and pull to get the 10,000 psi output when needed.
Crescent Tiger myself. Small world sometimes! :)
Must be a much better hose on that grease gun. The ones I used would 'swell' when I had a hard zerk. On the long one, I'd probably need one tube just for the hose!
/ Good grease gun needed! #28
Yep, small world. We used to live south of Cashion.
Don't remember where I ordered the hose from (probably eBay) but it was rated for high pressure grease guns.
Edit: Checked eBay order history:
It is a swell hose, but it does not swell. :D
/ Good grease gun needed! #29
I have an Alemite lever gun my Dad bought new in the late 50's, I still occasionally use, and still works great. It is a pre-cartridge gun, and you have to load it from a bulk bucket. I'm guessing from their new gun prices, hopefully they've kept that type of quality.
A cartridge grease gun seems like a simple thing but, honestly, after trying some ~$20 ones I guess not, or the manufacturers just don't care about quality.
The 7K~10K PSI grease guns I can understand being relatively pricey like almost anything requiring tight tolerances and better than average manufacturing quality but again, we aren't talking about Blue Origin, Space X, Virgin Galactic or, NASA levels of 'rocket science' either.
I would think a major manufacturing concern should be capable of making a profitable grease gun in the $50 retail range whether in the USA or overseas but, I'm seeing a lot of them in the $100 and up range. :eek: On the flip side, a lot of those ~$100 grease guns are probably overkill for most people so, low sales volume supports higher pricing; sort of chicken and egg - if it was $50 they would sell a lot more units but would the gross profit be the same as with a lower number of units with a fatter profit margin?
/ Good grease gun needed! #31
Lincoln 1148 under $30, or Alemite A500 under $40, both made in china. Neither of these are junk.
Thanks! I haven't seen either one of these in person so, my China grease gun experience is all bad.
/ Good grease gun needed! #33
You can always try a flea market or yard , estate sale for a old Alemite or lincoln made in the usa:D
Yes, I go to auctions and look for hidden gems like this but, I suspect the old grease guns are either claimed by family members or auction hands. Someday, I hope to find one on the auction table.
/ Good grease gun needed! #35
And a Wilton baby bullet vise:)
Yes, if I ever see a Wilton vice that isn't totally trashed out or bid up to unreasonable levels by a city slicker, it'll come home with me!
/ Good grease gun needed! #37
Love my Wilton 5" vise. Second one I've had. Simple. Bull strong. Never fails.
Rogator RG1100 (A63689)
Rogator RG1100...
Schuler Feed Wagon (A66408)
Schuler Feed Wagon...
SWINGTEC D-88307 COLD FOGGING APPLICATOR (A64276)
SWINGTEC D-88307...
New/Unused Wolverine Quick Attach Auger (A65583)
New/Unused...
2019 FORD F-350 (INOPERABLE) (A65643)
2019 FORD F-350...
2018 Deere 650K LGP (A64127)
2018 Deere 650K...
