Good grease gun needed!
   / Good grease gun needed! #1
Sid Post
Platinum Member
TX and OK
Massey 5711D, Kubota L4600, Kubota B2601
If you wanted a good grease gun, one that will work with tough zerks that put up a bit of struggle, what would you get? I need one with a fixed neck and a long handle (no pistol grips). I have tried the cheaper options from all the local places, Atwoods, Harbor Freight, WalMart, TSC, etc. I expect to spend ~$60 but, can go a bit higher if there is good reason. On the other hand, if what I want is available cheaper, I'm certainly receptive.
I live in East Texas and grew up in Central Oklahoma so, retail locations along the Interstates are fair game but, I'm expecting to mail order something.
TIA,
Sid
   / Good grease gun needed! #2
I've had good experiences with Lincoln brand grease guns but am now using a Milwaukee M18 with a LockNLube.
   / Good grease gun needed! #3
- To get a good Grease Gun, you WILL need to spend more than $60 !
Depending on the amount of greasing you have to do, I do my own vehicles, included a car, a truck and tractor... and a few smaller things requiring grease.
I purchased a DeWalt Battery Operated Grease Gun; it is powerful, gets grease in where you would think it wouldn't; I added a Lock-n-Lube Grease head to hold to the Fittings, best thing I ever did.
It isn't the lightest gun out there but it is the best one I have ever used, the hose on the gun isn't as long as I would like but it can be replaced as I did the head.
It gets the job done !
Lock-N-Lube sell a foot pumped grease gun... a little too much grease for my needs and a little too expensive; more than the DeWalt !
Good Luck on your search, post up what you find !
   / Good grease gun needed! #4
DeWalt 20V ($124)
I bought a new Lincoln pneumatic, and threw it away.
   / Good grease gun needed! #5
Go with a Alemite if you want a lever gun. One of their guns is a high pressure unit pushing 15,000lbs. I have a old unit that I can switch the linkage from high pressure to high volume.
   / Good grease gun needed! #6
I use Lincoln 1147 manual grease guns (lever with hose). The 1148 is the same gun but with a fixed neck. The Alemite A500 is also well regarded. Both are 10,000psi rated guns and are very affordable in the $30 range. I use the Lincoln and put 20 or so tubes through it a year, durability has not been an issue for me with it. I mostly grease equipment so high volume is not needed, higher pressure would be nice, but it would probably just cause me to squirt more grease all over....
The Alemite 6268-2 is the 15K unit that Ruffdog refers to, its currently $720.50 on Amazon.
The Alemite 1056-SE4 is the dual high pressure / high volume unit and is $112.39 on Amazon.
   / Good grease gun needed! #8
Ryobi has worked great for me so far.
   / Good grease gun needed! #9
All my cordless tools are Dewalt so I bought an 18v grease gun. Makes maintenance intervals a pleasure.
   / Good grease gun needed! #10
I have a Lincoln pneumatic hand held I got of an amazon warehouse damaged box deal for 50-ish bucks. Works great and much needed when owning a backhoe.
2020 John Deere 6105E 2wd cab tractor (A44789)
2020 John Deere...
Liebherr LR 621B (A42021)
Liebherr LR 621B...
2006 INTERNATIONAL PAYSTAR 5900I (A45333)
2006 INTERNATIONAL...
2016 Freightliner M2 106 Braun Ambulance (A42742)
2016 Freightliner...
RIGID 150 PSI AIR COMPRESSOR (A45333)
RIGID 150 PSI AIR...
John Deere 1200A Bunker Rake (A42744)
John Deere 1200A...
