Good Deal?
   / Good Deal? #1
TomIre
College Grove, TN
Branson 3725
Really know nothing about equipment trailers. Found a used one. 10 foot, single axle, 6,500 lb axle, wood deck in good shape, tilt bed, good tires with spare, break away brakes. $1000. Seems like a good deal. What do you say?
Tractor weighs 4400 lbs dry and I'd also haul a Kubota RTV side by side. Both would be occasional use. Tow vehicle, Chevy Colorado rated for 7000lb tow.
   / Good Deal? #2
Price seems good, but I personally do not like small trailers for heavy machinery.
4400 lbs is a lot of weight on a single axle trailer, and at best will be a stressful tow.
jmho... others here use small trailers.
   / Good Deal? #3
Tractordata lists the Branson 3725 as 129" long, don't know if that's w/ FEL but suspect not. So that gives you a 9" hangover. Do you have a FEL? Will you want to carry ANY attachments? Even 4 chains and fuel might add a hundred pounds or so. How much does the trailer weigh?
Seems for a maybe 5 hundred more you should be able to find a 4 wheel trailer w/ a 7k capacity.
And trust me - 4 wheels are nice. My 12K Hudson had a blowout one week ago on I81, tore the tire apart, smoking when I stopped. But since I had another tire on that side the only damage besides the tire was to my wallet. Slap on a spare and roll on. Didn't even hurt the rim.
If you are only going to tow short distance SLOW local it might be worth the chance.
   / Good Deal?
Thanks for the feedback. Really helpful and some things I had not thought about. Probably more marginal than I was thinking. Hmmm.
Where would you go to find a used trailer? Craigslist?
And, sorry I got this in the wrong sub forum. Fat fingers! Anybody know if I can move it?
   / Good Deal? #5
<snip>
CL is ok, but more seem to be advertised on Facebook --> Marketplace. But it's a pain to muddle through.
As far as moving the thread, ask a moderator or start a new one.
2023 CATERPILLAR 299D3 XE SKID STEER (A52705)
2023 CATERPILLAR...
2010 Turfco Mete-R-Matic III Pull-Behind Top Dresser (A54811)
2010 Turfco...
2016 Big Tex 14ft. T/A Hydraulic Dump Trailer (A50322)
2016 Big Tex 14ft...
230112 (A53422)
230112 (A53422)
2000 Mercedes-Benz S-Class Sedan (A53424)
2000 Mercedes-Benz...
2019 Dodge Durango (A53421)
2019 Dodge Durango...
