good cheap paint??
/ good cheap paint?? #1
Soundguy
Old Timer
Central florida
RK 55HC,ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
I need to get some flat black exterior ( latex?? ) paint for a small wooden structure.
I'm looking for 'cheap'. I'm painting a small wooden structure that will be setting in a paintball field. Estimated lifespan of the structure is 2ys or less, as they re-arange the 'bases' on the field every couple years.. so I'm just looking for something to hold the rain-rot at bay for that period. It's exterior plywood construction.. etc.
Each of the members of the field try to contribute a bit to the maintenance and upkeep of the field to keep the owners costs ( and more importantly PRICES )down.. so our team's contribution this time around is this mobile 7'x12' plywood bunker/pillbox.. etc. My other tem members are cash poor right now, so it's all on my dime, and my other 3 team mates are providing the labor. I'v already layed out about 195$ on the wood skinning and frame, screws, staples, screen material, and glues/caulks, etc. Once it gets finished ( this weekend?) I want to get paint on it and haul it over to the field.. my wife keeps harping about how it looks like an eyesore setting int he back bay of the barn..e tc.
So any ideas on good cheap paint.. I've got about 180 exterior sf to cover..( interior too?? ) I'm figuring on using a roller to paint it with.
Soundguy
/ good cheap paint?? #2
home depot has paint form time to time very cheep. People have it mixed and it is wrong...seems they could remix any color and make it black
/ good cheap paint?? #3
Soundguy,
Look at TSC. You can get barn paint in 5 gallon buckets around $40 I think. It only comes in white, green, or red, but I am sure you could probably take it somewhere to be tinted.
Fig
/ good cheap paint?? #4
There's always a deal on the classifieds, but you never know when they will apear.
Home Depot usually wont remix there return paint for the same price they are selling it, but I always look on the shelf to see if they have something I can use. Several times I've been lucky and bought some really good paint for $5 a gallon.
My usuall source for paint is Wal-Mart. It goes on good and so far has lasted several years. I forget the price, but it's proabably gonna be the lowest of any department store.
/ good cheap paint?? #5
Tractor Supply also has acrylic black barn paint in 5 gallon buckets for around $20.00 depending on your area. Sometimes it isn't in stock at every store, but it is listed in their blue book. It's advertised as not rubbing off like the inexpensive asphalt paint, but I haven't personally used it. I plan to in the near future though, for a fencing project. If you try it, let us know how it goes.
/ good cheap paint?? #6
</font><font color="blue" class="small">( I'm painting a small wooden structure that will be setting in a paintball field. Estimated lifespan of the structure is 2ys or less)</font>
Soundguy,
This may be a dumb question but if it's for a paintball course won't it be covered with paint pretty quickly anyway?
When you say the lifespan is a couple years, is it torn apart or re-used? If torn apart, won't the plywood and stuff last 2 years without being painted?
Anyway, I'll 2nd the tyoughts on checking with Home Depot, Lowes... for pre-mixed that someone didn't want.
Brian
The paintball marking paint is non permanent.
Also.. down here in florida, there is so much humidity/moisture/rain, etc, that untreated unpainted plywood usually looks pretty rough in a year.
After a couple years the material is either re-used, or if it has substantially fallen apart or been damaged beyond easy repair.. it is 'bon-fired'.
Soundguy
/ good cheap paint?? #8
I recommend an oil based paint for the sake of waterproofing and durability, cleanup with gas. I bought the KILZ brand paint, oil based, had it tinted and then diluted it with mineral spirits before spraying my shipping container with it inside and out. I sprayed through a 20$ automotive type paint gun, highly recommended.
The whole 20'x8'x8' container took less than 2 gallons of paint. I had it tinted to an olive drab. Works great and repels water. The KILZ is also available at the HD but costs more than 4$ per gallon.
/ good cheap paint?? #9
Most paint stores (Mautz, Sherwin Williams, etc.) have "unused" paint they offer at very low prices. This is usually extra paint that contractors ended up having left over. Sometimes it's paint that was mixed improperly colorwise. You could check with these stores and see if you could get some, although getting black might be a problem. Also be aware that sometimes, the store will require the purchaser to take everything they have.
/ good cheap paint?? #10
Why don't you post a "Wanted" ad in your local freecycle:
www.freecycle.org
You'll likely get plenty of responces from people happky to get rid of their old paint...Scozz
/ good cheap paint?? #11
I have had some luck getting the paint from LOWES when it was mixed wrong & or brought back. I actually had 30 gallons of barn paint (25 year 7 severe weather paint, mixed when I got up from low & behold was 10 more gallons already mixed up in the same color all for $1.00 a gallon /forums/images/graemlins/smile.gif /forums/images/graemlins/blush.gif luckly I was only getting the first batch I ended up taking those too and the normal cost was 80.00 for 5 gallons then I got the 10 gallons for 10 bucks /forums/images/graemlins/wink.gif I ended up mixing them together just to make sure there awsn't any difference I mixed 5 gallons of my mix to the 5 gallons of the cheap mix (same brand I say cheap cause it was only 1buck a gallon) they were indistinguisable by the eye, I still mixed the next 10 together too...
anyhow this year I think I should re-coat the weatherbeater STAIN (not paint) anyhow nice misty blue color...
also the 20gallon enamel paint at TSC workes quite well too and is very durrable, I got the hardner for mine when I painted my dump wagon 2 yrs back and it still hasn't rusted cept where the rocks scratched it off.. it is left out in the woods 24/7.
One other place is Big Lots or ODDLOTS closeout store, usually 9 bucks a gallong for latex exterior. mixable usually and they often have tint too.
MakrM
/ good cheap paint?? #12
I bought some Walmart exterior latex 3 years ago. Still holding up strong on my shed i beleive it $12 a gallon. I like to get the $5 gallon home depot stuff when they have some good colors.
/ good cheap paint?? #13
If dark but not black will work try tar and kerosene. Let delute a few days then apply.
Mexicans heve been using this for stain for years.
/ good cheap paint?? #14
For years, I thinned my oil based paints with mineral spirits or lacquer thinner. I notice my paint jobs faded rather quickly if they sat outside for a couple of years. Now days, I thin with enamel reducer and I use a brand matched with the paint. As an automotive painter explained to me, paint cut with lacquer thinner will go on just as shinny as any, but the color will bleed out quicker – especially if exposed to sunlight. Now days, I only cut my primer with lacquer thinner.
/ good cheap paint?? #15
Soundguy, my neighbor is the re-cycling coordinator for our county and has her office at the county re-cycling center (aka landfill). One of the things they get the most of is old paint (oil too). So, you might try there and it'll be free or a small donation to their re-cycle fund is all.
Nice idea BTW, wish they'd do something like that here.
Good luck.
/ good cheap paint?? #16
Do nothing...I have a deer stand named the "Condo" that has stood 8 or 9 years in the weather. Half inch exterior plywood.
Or...buy a couple of cans of Krylon and give them to the kids to graffti the pill box, with offensive slogans towards the other teams. In no time the other teams will retaliate and paint the rest for free. /forums/images/graemlins/grin.gif
/ good cheap paint?? #17
I get out of date paint for free from a local Sherwin Williams dealer (I'm a really good customer, I paint murals for a living)- I don't use it on jobs but it works fine for painting things around the farm. It's woth asking - you can make black out of any deep base exterior paint.
/ good cheap paint?? #18
what kind of murals do you do and what type of air guns? I have been using Thayer Chandlers for probably 25 years,, Thought of trying others, but stick with T&C... I am very part time at air brushing,
(INOP)1989 NISSAN D21 EXTENDED CAB TRUCK (A65054)
(INOP)1989 NISSAN...
Preliminary Listing / Full Catalog Coming Soon! (A62177)
Preliminary...
2006 PROCO  130BBL (A65643)
2006 PROCO 130BBL...
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
1991 CAT 3406 Generator Set 400KVA/320KW, 480V 3-phase, 60Hz, Industrial Standby (A63689)
1991 CAT 3406...
2008 Kawasaki ZX1000 Motorcycle, VIN # JKAZXCE1X8A013733 (A65563)
2008 Kawasaki...
