good buy?
   / good buy? #2
Do you have 3-phase power at your house? The link states that welder requires 3-phase power input. In the U.S. typically only large businesses have 3-phase power so a homeowner would be required to buy a phase converter to use this at home - which can be prohibitively expensive. Hence, The 3-phase power requirement would drastically affect the value from a homeowner perspective.
That said, that appears to be a lot of welder for very little money if you are lucky enough to have the 3-phase input power needed to run it. I doubt you would ever outgrow it from the welders capability perspective as it states a welding output of 375 amps which is huge and capable of running extremely big rods which most homeowners will never be welding metal that thick.
   / good buy?
I do not have phase 3 power at home.
Sounds like it has more jam than I will ever need.
Thanks very much for the advise.
The hunt continues.
   / good buy? #4
You can look into a used Lincoln AC/DC on Craigslist. I'd recommend something with DC welding capability but AC only is far cheaper for occasional farm use.
If you want to buy new a Everlast PowerArc 160 or 200 can be bought very reasonably. They are DC, 220V, and light as a feather (comparatively). Very easy to learn on and put down gorgeous welds with just a little practice.
   / good buy?
You had me at...
very easy to learn on
   / good buy? #6
Yes i feel it's worth it. You can carry on with it.
   / good buy? #7
I agree that the Everlast Power Arc 200, is really forgiving. It was making better welds in a half hour than any weld I ever made on an AC buzz box.
JOHN DEERE 54D LOT IDENTIFIER 147 (A53084)
JOHN DEERE 54D LOT...
2008 FORD RANGER SINGLE CAB TRUCK (A51406)
2008 FORD RANGER...
2024 Dig Master DM100 Mini Excavator, NEW! (A52384)
2024 Dig Master...
UNUSED SWICT 78" QUICK ATTACH BUCKET (A51248)
UNUSED SWICT 78"...
2020 UNVERFERTH 332 LOT IDENTIFIER 185 (A53084)
2020 UNVERFERTH...
66 Tomahawk Skid Steer Bucket (A52384)
66 Tomahawk Skid...
