Good 3pt 12V sprater - What to get
   / Good 3pt 12V sprater - What to get #1
powerscol
SW Colorado
CT 235
   / Good 3pt 12V sprater - What to get #2
I have owned two similar sprayers;fairly durable.Rinse the pump with clear water when done.Not a lot to go wrong with one unless you "crash" it.
   / Good 3pt 12V sprater - What to get #3
hand gun / spot sprayer. make sure you get something with extra hose.
the hand gun itself. prefer something i can toss on some extensions (cheap plastic extensions), for about 4 to 6 feet length. with an adjustable tip.
--you might consider a 3pt hitch forks, or 3pt hitch carry all. and then getting a "skid version" of a sprayer. so you can re-use forks and what not for other things.
--if you have a FEL (front end loader), just toss something into the bucket if your just spot spraying.
--make sure the primary filter just before pump inlet is easily accessable for checking and cleaning.
--for boom nozzles. see if they come with a little "filter" inside the nozzle. and some sort of mini valve to adjust amount of liquid each nozzle gets.
--look at bottom and see if you can actually drain all the liquid out of them.
--see if there is a "cleaning wand" or "mixer wand" inside the tank. (pipe going through it, with a bunch of holes in it) to make cleaning easier, and/or help mixing chemicals with water better.
--if you have hills, check to see if tank has any sort of "baffles" mini walls inside the tank, to help reduce sloshing of the liquid. if not a smaller tank can help reduce sloshing within reason.
--garden hose, some of them can be "a pain" toss garden hose entire end of hose into tank and hope hose will not fall out as you walk away getting other things ready. there might be a garden hose hookup or "quick connect" that might be easier done.
electrical wise
--see if it comes with a fuse (possibly fuse located at/in the pump itself (standard vehicle fuse most likely))
--dip switch SPST (single pull single through), might be nice mounted at tractor, so you can adjust booms, and then flip switch on/off when turning around and like.
on demand pump, hand gun/spot sprayer w/ extensions, boom nozzles, and primary filter there is not a lot to them. most of it is just did manufacture have there head screwed on correctly when they built it in laying everything out. one of those things is extra hose for the hand gun/spot sprayer, and jacking it around and pulling the hose around, and then coiling hose backup, and uncoiling hose. some are good some are bad. and can leave your hands a mess of chemicals dealing with the hose.
   / Good 3pt 12V sprater - What to get #4
Ive been happy with the fimcos ive had. Whichever you get a on demand pump is preffered. How much acreage are you spraying ?
Up to 26 acres, but most are 2 to 3 acre fields, so need precision to not over spray to others lots.
   / Good 3pt 12V sprater - What to get #6
I have used rented boom sprayers and for smaller plots with fences you have to be good at guessing.......keeping the boom tips out of the fences, trees or what have you. I use the single point spray head that shoots about 15' to each side at about 25 psi....low psi to keep the droplet size large to reduce drifting.
The head comes off and you can flip it over if you only want to spray one side, like you are coming around your pond bank and only want to spray the side away from the water.....to help in reducing your unwanted vegetation. For rough terrain this would be good as the booms wouldn't be flopping up and down.
The spot sprayer, or tree top sprayer as I use it is a no brainer, just put in a TEE and a couple of plastic shut off valves and direct the flow to whichever you want. The wand has a trigger for on-off control in addition to the PTO which is your main on-off switch. If you are using a PTO gear pump you have to have an outlet somewhere if the PTO is running and using the wand with the trigger off. AT 25 psi pressure a centrifugal pump will work great and you don't have to worry about overpressuring when the wand handle is off and the PTO running.
The nice thing about the 12v motors is the pressure switch which turns off the power to the mower when line pressure meets the set point.
Well folks I decided to re purpose my existing sprayer. I got a cheap cargo carrier from harbor fright to use with my 3pt hitch. Now I need power to the rear of my tractor. Tried searching here, but mixed results. Any idea of a plug and harness that could be used for this and to run my hay monitor?
2017 DRAGON 48' ROLL OFF TRAILER (A50854)
2017 DRAGON 48'...
2014 INTERNATIONAL PRO STAR (A50854)
2014 INTERNATIONAL...
72in Rock Bucket Skid Steer Attachment (A50322)
72in Rock Bucket...
2015 F-550 Bucket Truck Gas Engine (A52128)
2015 F-550 Bucket...
2013 Ford E350 Box Truck (A47384)
2013 Ford E350 Box...
2012 UTILITY VS2DX 53FT DRY VAN TRAILER (A52141)
2012 UTILITY VS2DX...
