golf cart top and quick attach and lights and tool boxes and hydraulic top link
   / golf cart top and quick attach and lights and tool boxes and hydraulic top link #1
goneblue
Florida
Ls G3038h
Got a golf cart top and some steel tubing for less than $100 and welded up a top for my G3038H and it fits in a regular single car garage. The way I welded the frame
makes the top come on and off and the rops pulls back and have about 1 inch clearance to get in my garage. added a hyd. top link and gives me the same travel
with a box blade both directions. just did the 50 hour service, found a few loose bolts, but went pretty easy. Got a quick release from harbor freight and spent a day
going over their welds and adding some supports and put 1 1/2" steel bushings on grade 5 bolts so there is no slop in the lower arms. did the 1 1/2" bushings on my
bush hog, box blade and landscape rake. all pick up very easy and quick and no slop at all . took quite a bit of custom fitting but was worth it.
   / golf cart top and quick attach and lights and tool boxes and hydraulic top link #2
Nice job on the Golf card lid. Two tool boxes that just isn't fair!
   / golf cart top and quick attach and lights and tool boxes and hydraulic top link #3
Yep, nice job. Around here, any permanent modifications (welding, holes) to a ROPS makes it very hard to trade or sell. They figure a new ROPS replacement into the cost most times.
   / golf cart top and quick attach and lights and tool boxes and hydraulic top link #4
Nice work goneblue, good looking Rig!! :thumbsup:
   / golf cart top and quick attach and lights and tool boxes and hydraulic top link #5
The mirrors are very stable. Very nice when grading a road
   / golf cart top and quick attach and lights and tool boxes and hydraulic top link #7
Got a golf cart top and some steel tubing for less than $100 and welded up a top for my G3038H and it fits in a regular single car garage. The way I welded the frame makes the top come on and off and the rops pulls back and have about 1 inch clearance to get in my garage. added a hyd. top link and gives me the same travel with a box blade both directions. just did the 50 hour service, found a few loose bolts, but went pretty easy. Got a quick release from harbor freight and spent a day going over their welds and adding some supports and put 1 1/2" steel bushings on grade 5 bolts so there is no slop in the lower arms. did the 1 1/2" bushings on my bush hog, box blade and landscape rake. all pick up very easy and quick and no slop at all . took quite a bit of custom fitting but was worth it.
What paint did you use? Seems to match the LS blue very well?
Sent from my iPad using TractorByNet
check out a thread I posted here on the sherwin williams paint code for LS blue
   / golf cart top and quick attach and lights and tool boxes and hydraulic top link #9
Found it. Thanks! About how much was the gallon you bought at SW?
It is industrial quality and was about $100 per gallon, but if
you can set up an account with them it saves about 50%. It has not
rubbed off the bush hog or boxblade and you know what they go through.
It is much better than I expected.
2000 Freightliner FL70, 5.9 Cummins (A52384)
2000 Freightliner...
2019 MACK GR64F TANDEM AXLE CEMENT MIXER TRUCK (A52577)
2019 MACK GR64F...
2015 Ford F-150 4x4 Pickup Truck (A50323)
2015 Ford F-150...
2003 John Deere 270 Series II Compact Wheel Loader Skid Steer (A50322)
2003 John Deere...
2013 COACHMEN CATALINA TRAVEL TRAILER (A52472)
2013 COACHMEN...
