dieselfuelonly
Hi guys, I'm new here, and I'm going to look at a tractor tomorrow.
Heres the background:
I've got 6 acres of land in Chapel Hill, NC. My little riding mower will no longer "cut it" when it comes to keeping the fields trimmed.
I am looking for a tractor mainly to put a bush hog on just to keep the grass mowed. I also would like to get a post hole digger so I can repair the fence in some areas. A front end loader, box blade, a plow and a disk would come in handy too but are not necessary. Right now I just want to mow.
After looking at a MF 135 yesterday, I have decided to keep looking. It was the European model, and had a bad oil leak and looked pretty rough and needed some parts replaced. The oil was all down the right side of the engine, the ball joints had a lot of play, and the power steering hoses needed to be replaced.
I found a guy selling his Nortrac tractor, 20hp diesel, 4wd. Its only got 60 hours on it. New it sells for 6k, he is selling it for 4k, I would probably offer $3,500.
He says it has no mechanical problems other than a small leak by the steering wheel that occurred when he first got it, but he fixed it (he said this was a common problem with the new ones, is that true?).
Anyway, what should I look for? What should I test out, turn on and off, smell, feel, etc. I want to make sure I am making a good decision.
Would this tractor be a good combination with a 4' bush hog? I don't need any new equipment, as long as it is in good mechanical condition I don't mind if it is used in the least.
Thanks!
Dennis
Thanks!
Dennis
