Going in reverse?
/ Going in reverse? #21
Get lost troll. Your kind isn't welcome here.
By saying something so (what I thought) outrageous silly, I really didn't expect anyone to take it serious. It was meant to make you smile like it did me. Certainly not make you angry. So to you I'm sorry.
/ Going in reverse? #22
dwitt, the thing you may only now understand, is that, anybody reading your post may not recognize it as "outrageous silly". Best to keep suggestions factual, identity them as a not-serious suggestion or just continue to monitor this site.
/ Going in reverse? #24
FWIW, I double checked my manual and the only warning about diff is not to use when one tire is spinning and the other isn't.
/ Going in reverse? #25
Yes, my manual says the same thing. It goes on to say that engagement with one wheel spinning may damage the differential. I've used the diffy lock several times - both forward & reverse. Usually in snow/icy conditions. I just push in the clutch, let everything come to a stop, step on the engagement lever and let out the clutch.
/ Going in reverse? #26
I usually stomp on mine when I'm on firm ground before I hit the slippery looking bit. No reason to loose momentum by stopping.
/ Going in reverse?
Thank you for all the replies. I have a better mindset about how to use the locking differential now. I sure don't want to tear anything up. Kubota Insurance would be very upset with me...:thumbsup:
/ Going in reverse?
"I usually stomp on mine when I'm on firm ground before I hit the slippery looking bit. No reason to loose momentum by stopping."
I have never thought about doing this when approaching the slippery stuff. :thumbsup:
/ Going in reverse? #29
Just make sure things arent slipping. The only downside with this method is you dont have an extra tool to get unstuck if/when you do actually get stuck. So you can get yourself really stuck. I often use the method when plowing snow or box blading, as getting unstuck is as simple as lifting the blade.
/ Going in reverse? #30
... and remember - you're split brakes are not a steering option as long as the diff-locker is engaged.
-Jim
/ Going in reverse? #31
I understand what you are saying, but when I'm plowing snow, it is frequently all "slippery stuff". It's sometimes hard to tell when you'll spin out and when you'll be fine.
