Going forward and backward
   / Going forward and backward #1
Jeffory
Rector
JD 5085E
Do I need to push the clutch in when I move the lever to change directions? I have a JD 5085E.
   / Going forward and backward #2
Put your foot on the break and stop it then your good to go no clutch necessary.
Thank you
   / Going forward and backward #4
No clutching or braking required on power reverser. The reverser should modulate and make a smooth shift. If it is too jerky, it may need calibration. If transmission does not engage when shuttle shifting, you may have a problem with the seat switch.
Everything works fine. I had two people tell me I was doing it wrong. I was not clutching, always at slow speed, low RPM. Mostly when I move hay.
   / Going forward and backward #6
I have a power reverser tranny also. I move lever to neutral wait a moment then to the other direction.
2012 Chevrolet Malibu Sedan (A50324)
2012 Chevrolet...
Case 580D (A47384)
Case 580D (A47384)
Grady-White 17ft Fishing Boat with T/A Boat Trailer (A50324)
Grady-White 17ft...
2009 KUBOTA M7040 TRACTOR (A51406)
2009 KUBOTA M7040...
2004 TRAILKING 101" X 53' STEP DECK TRAILER (A50459)
2004 TRAILKING...
SAKAI SW502S-1 SMOOTH DBL DRUM ROLLER (A51242)
SAKAI SW502S-1...
