Goat Shed Siding
   / Goat Shed Siding #1
barticus73
Clarksburg, Pa(Between Indiana and Saltsburg Pa)
Cub Cadet 7272,Farmall 544
I built a 3 sided 8' x `12' run in shed for my goats in a new paddock. I need to side it and typically have used rough cut hemlock 1x 10's or so. But, the problem right now is none of the lumber mills around me have any 1x's cause the price of whole logs is very high right now and they can't get any in to cut up. This leaves me with a dilemma of what to side the shed with. Do you guys think t-111 would work? Lowes has T-111 for $28 a sheet unprimed and primed for $20 a sheet? The primed is actually cheaper for some reason? I have never used this stuff and wondered how well it will hold up. Also, I don't like the idea of metal sides cause I don't want an animal busting through one and getting all cut up. Are there any other options you guys can think of? I never thought I would have trouble getting wood!
   / Goat Shed Siding #2
I think T111 will work if you don't mind re-painting it every couple of years. I'm not sure of the cost difference, but I'd probably want to use metal but with plywood (horizontal sheets) for the lower 4' on the interior side.
   / Goat Shed Siding #3
The primered boards your looking at is most likely masonite panels. For your aplication i would stay away from it. if you've got trees on your land would it be worth while to have some cut by a small saw mill or even one of those things that mounts to a chain saw to cut boards?
   / Goat Shed Siding #4
Bird, have you been looking at my horse shelters?
I used metal siding for the exterior and OSB to 8' for the interior to keep the horses from banging up the interior. It also helps with cleanup to have a smooth interior at the bottom. I think 4' inside would be adequate.
   / Goat Shed Siding #5
I used T-111 on my goat sheds and found the goats will eat it. Chicken wire stapled over it will stop that, though.
   / Goat Shed Siding #6
Why not use OSB? It's exterior grade, should be plenty strong for goats and it hold pain OK. The only real drawback is it's not the most attractive sheeting out there, but the goats wond care.
Eddie
   / Goat Shed Siding #8
The primed could have some defects that would have prevented it from being stained and have a nice look. You see this in cheep trim that has many finger joints.
Not sure, just guessing
   / Goat Shed Siding #9
barticus73 said:
Is all OSB exterior rated or are there different versions?
The t1-11 is $28 a sheet at the local Lowes FYI.
I honestly don't know for sure. I just buy what's on the floor at the store and use it. I've never checked to see if there is different ratings on it, so I really don't know.
I've used it on sheds and outbuildings for years without any problems. But like I said, even when you paint it, there is a pattern that isn't as nice looking as other materials. One side is smooth from all the glues and resins used to make it and tha's the best side to have exposed to the weather. The other side is rougher and I'd expect more prone to holding moisture if left unpainted.
One thing I should add is that it's a good idea to protect the top edge. I use Z flashing, or just tuck it up under an eve. No matter what you use, you don't want to let water sit on it. Sooner or later it will work it's way between the layers.
Eddie
2016 KBH Fertilizer Tender Trailer - Isuzu Diesel, Hydraulic System, Rear Discharge (A55301)
2016 KBH...
2015 FORD F550 XL SUPER DUTY SERVICE TRUCK (A51406)
2015 FORD F550 XL...
2013 KENWORTH T800 DAY CAB (A54607)
2013 KENWORTH T800...
2024 Big Tex 14GN-40D5A 35ft Gooseneck Flatbed Trailer (A51691)
2024 Big Tex...
NEW Woods Reverse Rotation 5ft Tiller (A55218)
NEW Woods Reverse...
UNUSED Jack Lift 5/10 Ton (A53117)
UNUSED Jack Lift...
