Go peddle bolts CT235
/ Go peddle bolts CT235 #1
powerscol
Veteran Member
SW Colorado
CT 235
I lot a bolt out of the go peddle so it no workee - just flops front to back. I am pretty sure it is metric. Its bolt #4 in the attachment. Dealer has one, but I am sure I have one in my bolt collection. Just trying to save time.
Title: HST Control 2 Group Model Number: CT235 Serial Number: A9JY11001 & Above
  • HST Control 2 Group_CT235.pdf
/ Go peddle bolts CT235 #2
The Kioti parts manual shows them to be M8x1.25.
When you remount the treadle make sure it has full travel for and aft. It is possible to install the treadle and find that Rev is much faster than before, but foward is now slower.
I found a metric bolt in my spares. Head was marked 10.6 fine thread and it worked. So folks know there is a capture nut welded to the back side of the plate the peddle is attached to.
/ Go peddle bolts CT235 #5
Usually the head markings on a metric bolt are the hardness, not the size. Not familiar with 10.6, but 10.9 is a common hardness.
Jack
