Go Kart will not get moving
   / Go Kart will not get moving
I took a closer look at this last night. I put a new belt on and it didn't make any difference.
I guess I just don't understand how the clutch functions. I took it apart and all the springs are there. The wheel that I took off to see the clutch did appear to have a ridge worn into the inside of it. The clutch also appears to have an uneven surface, although I don't really know what worn out would look like.
Does this sound like I need a new clutch or the outer wheel (whatever that is called that the belt goes on)?
   / Go Kart will not get moving #12
How about some pictures. Did you look at the pulley set up. Does one side of the pulley have more of a slant than the other. Uneven surface does not sound good. If the wrong belt has been used for a while, it could have worn a ridge/gouge, where the pulley top edge was getting most of the friction. I would just throw in the truck and go by a cart dealer/repair place and he could look at it and fix you up. Long distance mechanical analysis is difficult at times.
http://www.gokartsupply.com/trouble.htm
http://www.gokartsupply.com/tcterms.htm
http://www.gokartsupply.com/asymapp.htm
Thanks for the replies. I'm going to run by the go cart shop when I get a chance.
I picked up a new clutch on Friday. The go cart now moves great and starts moving as soon as the gas pedal is pushed.
Thanks for all the help!
   / Go Kart will not get moving #15
Nice looking go cart, glad things are working for you. Its kinda nice when you identify a problem and can fix it yourself and all works out well in the end. :)
2013 Ford F-550 Ambulance (A56858)
2013 Ford F-550...
Case Wheels for Combine/Firestone Tires w/ extra rings NO RESERVE (A56436)
Case Wheels for...
UNUSED FUTURE WALK BEHIND POWER TROWELL (A52706)
UNUSED FUTURE WALK...
New Holland WorkMaster 37 (A53317)
New Holland...
John Deere HD300 Sprayer Utility Cart Attachment (A56857)
John Deere HD300...
25 DUAL AXLE GOOSENECK TRAILER (A58214)
25 DUAL AXLE...
