gn and 5th wheel differance?
/ gn and 5th wheel differance? #1
redman135
nz
Case 105c
Can someone explain the difference between a "goose-neck (gn)" and a 5th wheel please? Reading the various posts, it appears that they are 2 different hitch systems. What the U.S. members refer to as bumper pull is all I am familiar with.
/ gn and 5th wheel differance? #2
A fifth wheel is just what it says. A smaller version of a semi tractor connector. A gooseneck is a general term for a type of trailer but is generally regarded to mean a 2 5/16" ball in the bed of a truck that a socket on the trailer drops onto. The fifth wheel has a king pin that slides into the jaws and latches.
/ gn and 5th wheel differance? #3
With a few exceptions.......
Large campers are usually the only 5th wheel stuff you see.
Most equipment trailers, you rarely see 5th wheel.....always GN.
Given a choice.....I prefer GN. When you unhook the trailer....you bed is free.
Hello RedNeckRacin and LD1, thank you for explaining things.
2005 Isuzu NQR 4 door box truck with folding gate (A63689)
2005 Isuzu NQR 4...
UNUSED 2026 INDUSTRIAS AMERICA HYD TILT TRAILER (A60430)
UNUSED 2026...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2012 MACK Tender Truck w/ADAMS Rear Discharge Bed Auger (A63688)
2012 MACK Tender...
2007 Genie AWP-30S 30ft Manlift (A61572)
2007 Genie AWP-30S...
1137 (A63291)
1137 (A63291)
