GM tow/haul question
   / GM tow/haul question #1
deerefan
louisiana
1952 8N, 2005 JD 5103
My wife and I recently pulled our three horse trailer on a 2 hour trip, loaded with 3 horses, and averaged 13 mpg behind my 2005 Chevy Z71 w/ 5.3l. Of course, I had the truck in tow haul. One thing I noticed, especially coming home, was how much the truck downshifted. Now, I leave the trans in "D" and just push the tow haul button. Am I supposed to leave it in "3" so it won't shift into o/d and cause excessive heat in the tranny? I'm used to just turning the o/d off in my older trucks, not too used to this new tow/haul thing.
   / GM tow/haul question #2
Just stick it in drive, press the tow/haul button go on with life.
The tow/haul tries very hard to keep your speed constant for you when slowing, so it downshifts for you. (really sweet in the mountains)
also, it won't go into a gear it doesn't like.
   / GM tow/haul question #3
I agree 100% with LoneCowboy, I towed a 6 ton Toyhauler cross country last fall with Tow/Haul had no problems at all . I just put it in drive and let it do it's thing. It tends to shift at a higher RPM. The only thing I paid more attention to was the transmission temp guage.
Thanks, that was what I was thinking, but needed a little reassurance.
   / GM tow/haul question #5
What does your factory manual say about towing a heavy trailer.
It should be right
Jim:)
   / GM tow/haul question #6
Deerefan,
On my 05 Chevy the tow / haul mode is a push button on the end of the shift lever. Just touch it once for tow / haul mode. (probably the same as yours). To lock out overdrive I leave it in D and just push the button in and hold it a few seconds. The overdrive lockout symbol then lights up on the dash next to the tow / haul light. You should not tow heavy loads unless you lock out the overdrive as it will overheat the trans. The tow / haul mode raises the shift points while going through the gears so the engine isn't lugging. Try holding the button in longer and see if your O/D lockout light lights.
   / GM tow/haul question #7
George2615 said:
Deerefan,
That only applies if you have an Allison Transmission. All other automatic transmission change the upshifts, downshifts, engage the Torque Converter Clutch from 2nd gear and up. (This is a summary statement.) It is recommended only to use Tow/Haul when the gross combined weight is 75% or greater.
Kurt
   / GM tow/haul question #8
I guess on my 06 with allison I would just put it in Manual mode and put the selector to 05 and push the tow button. That should lock out OD and have me in tow mode
   / GM tow/haul question #9
Almost Correct - there are 2 overdrive gears on that Allison, but in Manual Mode you lose (with Duramax only) Grade Braking (unless you manually downshift - Tap the brake to have the tranny downshift) and Cruise Grade Braking (the vehicle will monitor speed while using cruise control and downshift accordingly to maintain speed)
Kurt
   / GM tow/haul question #10
All i know is that it is an awesome truck I dont regret that 15,000 I payed for my 06 duramax one little bit :)
2015 FORD F-250 XL SUPER DUTY TRUCK (A51406)
2015 FORD F-250 XL...
378670 (A51573)
378670 (A51573)
2025 New/Unused Wolverine Auger Drive and Bit (A51573)
2025 New/Unused...
New Skid Steer Attachment Plate (A53002)
New Skid Steer...
2010 FREIGHTLINER M2 BUSINESS CLASS CAB AND CHASSIS (A52472)
2010 FREIGHTLINER...
2003 Ford Excursion 4x4 (MPV), VIN # 1FMSU43PX3EC07978 (A51572)
2003 Ford...
