GM/Ford lying? Decide for yourself
   / GM/Ford lying? Decide for yourself #1
deerefan
louisiana
1952 8N, 2005 JD 5103
Read about it here.
Object moved
I don't see the big deal- we all know they fudged horsepower numbers during the muscle-car years to fool the insurance companies.
   / GM/Ford lying? Decide for yourself #2
Deerfan;
Don't get your link? Can you be more specific on your point?
Sent from my iPad using TractorByNet
   / GM/Ford lying? Decide for yourself #3
I'm not so sure they out and out lie these days. But connecting the dots to the truth is not a straight path.
Deerfan;
The link won't open? Not sure why. They are supposedly fudging payload numbers, the article pretty much sums it up. With all the truck debating on here, I figured I'd give them some more debate fuel.
   / GM/Ford lying? Decide for yourself #7
No, I don't understand what I am supposed to read on your link? Seems to be a general page with lots of subjects?
What is your point?
   / GM/Ford lying? Decide for yourself #8
There has been a couple of posts in the last couple of weeks in regards to this very issue. I know a lot of people have been knocking the newer Rams for not having the payload capacity of the Fords and Chevys. Maybe its just that that rate them at realistic numbers.
The way I have done it over the years may be incorrect but it works ok for me- 1/2 ton truck, 1k lb payload max. 1 ton- 2k payload max. It has kept me out of trouble so far and I have not broken anything...yet :)
   / GM/Ford lying? Decide for yourself #10
I weight all my trucks the week I get them or even on a test drive if in question.
This gives me a true weight with me in it then subtract that from the GVWR and check the axles and I know what I have.
For example, my 2006 F350 has a gvwr of 11,500# but weighs 7,600# with me so that leaves a honest 3,900# for payload.
Chris
UNUSED ECHO CS-4010 CHAINSAW (A51247)
UNUSED ECHO...
UNUSED HURRICANE 20' X 20' ALL-STEEL CARPORT (A51248)
UNUSED HURRICANE...
2021 New Holland C327 Compact Track Loader (A53473)
2021 New Holland...
UNUSED KIVEL 3500# PALLET FORKS (A51248)
UNUSED KIVEL 3500#...
48" JOB BOX (A51248)
2013 Ford F-550 Passenger Bus (A51692)
2013 Ford F-550...
