GM altenator on a Kubota
   / GM altenator on a Kubota #1
kuby
Alberta, Canada
L 245DT
My old L245 is giveing me headachs with its charging system and have mounted a GM delco altenator on it but am wondering how to wire it. The main red is easy but am confused to know which other wires need to be hooked up?
Thanks Bob
   / GM altenator on a Kubota #2
What alternator did you use?
On the Jeep I used to have, when I rewired it, I put a 110A GM alternator on it. It had one wire. I think the regulator was built in to the alternator...
Maybe check a 4x4/of-road shop, or custom car shop. It is pretty common to run an alterantor like that...
   / GM altenator on a Kubota #3
The two little wires on the GM alternator side are marked #1 & #2 (on the GM model 10 SI, or 12 SI). The #1 is hooked up to the idiot light, and the #2, gets hooked up to the big output terminal on the back.
There is a lot of info on the net on how to do the swap.
Good luck, Tom
   / GM altenator on a Kubota #4
Visit an alternator shop. I bought a plug that plugs into the alternaotor and has a diode attached to it. Wire the plug according to the instructions the alternator shop guy will tell you.
When power is on the plug the charger will charge, voltage regulated. Could not be easier. And Autozone sells them with a lifetime warranty.
2016 Chrysler 200 Sedan (A50324)
2016 Chrysler 200...
SCAN FOR HAULING AND FINANCING INFORMATION (A51244)
SCAN FOR HAULING...
2010 International 4400 National Crane 300C 56FT 8 Ton Crane Truck (A50323)
2010 International...
RING 2 STARTS HERE @ 9:30 AM (A51243)
RING 2 STARTS HERE...
2006 CATERPILLAR 320CL EXCAVATOR (A51242)
2006 CATERPILLAR...
Whiteman Concrete Trowel (A47384)
Whiteman Concrete...
