Glycol - Does colour matter??
   / Glycol - Does colour matter?? #1
WilliamBos
Super Member
Innisfil, Ontario, Canada
MF 1635 12x12 Powershuttle
Hi All,
We recently acquired a new MF 1523. I was amazed to see Ethylene glycol in it, was really hoping it had Propylene glycol in it. Anyway, we have 2 gallons of Red Texaco Ethylene glycol, but the stuff in the tractor is green, if needed can we add the red Ethylene glycol to the green??
Since the manual suggests annual rad flushes, we are seriously thinking of switching it too Dex-cool next year, after all, all of our vehicles are Dex.
Thanks,
Will
   / Glycol - Does colour matter?? #2
I have thought about switching my tractor to Dex-cool too. I have heard there are some compatibility issues with Dex and Ethylene glycol. I guess if we flush it out well it could be ok. There was some talk about coolant designed for Diesel. Not sure why it matters maybe someone will have the answer.
   / Glycol - Does colour matter?? #3
I don't think you are supposed to mix the two, and depending on the alloys used in the engine, one is prefered over the other. If you want to switch, flush throughly.
As I understand it, diesel knock in some engines can supposedly cause cavitation in the coolant, which can form air bubbles against the cylinder liner which can cause hot spots. Diesel coolant additives have wetting agents that help combat this and keep the coolant in contact with the cylinders to transfer heat evenly.
   / Glycol - Does colour matter?? #5
I will take a run at this.
The issue of "color" of antifreeze.
The color is a dye, different manufacturers use different colors to denote their products, or to denote different products within their lines.
That said, the "color" is not an industry standard, there are some generally accecpted standards withing the antifreeze community, but, there are some out there that do not follow the standards.
There are different types of chemistry involved in Antifreeze past whether it is Ethylene Glycol or Propylene Glycol, there are various additive packages and formulations that are added to the EG / PG and water mix that give your "antifreeze" those protective properties, sacrificial metals, Water pump lube properties etc. that you expect from your "antifreeze" then there are also supplemental Coolant additives (SCA's) commonly used for most diesel engines to prevent some of the special stresses that they incurr (cavitation)
So, normally, a color or dye represents a type of chemistry from a particular manufacturer. Normally it is not a good idea to mix chemistries. I would not assume from just a color that I knew what the chemistry of that particular AF was, especially without knowing the manufacturer of that AF.
If it were mine, I would check the manual, see what was reccomended, and drain and flush and replace accordingly. I would also be carefull that you do not decide to "halfway" follow the directions such as you decide that you want to run PG so it is "safer" then add in the SCA that was called for in your manual as it was likely not intended to be mixed with the chemistry used in formulating your PG antifreeze.
That said, if you run many vehicles, sometimes it is better to standardize across your fleet and run one fluid, that prevents incompatible chemistries from being mixed. IE, half dexcool, half standard EG. (this is what I do in the oils in my vehicles, we only run Rotella 5w40 so I only have to insure the folks are pouring it into the engine and I know which oil I should tell them too add)
If I was doing this, I would consult the AF manufacturer and get their reccomendation.
And on that front, I tend to use Fleet Fully formulated EG based AF and that lets me put that in all my vehicles and not have compatibility issues.
When I get a "new" peice of equipment, (I always buy used stuff) I tend to change all fluids and lubricants, and drain and flush and go to the "standard" that I use.
Sorry if I wandered too much, but if it did not interest you, I figure you stopped reading before you got here :)
   / Glycol - Does colour matter?? #6
I would do some checking on the Dex Cool. There has been some class action lawsuits on the product. I do know that in my Chevy Venture, I had intake manifold gasket failure, before the warranty was out and afterward. It would seem that this has been an issue with this product.
Do a search on Google and see what conclusion you come to.
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A51692)
2015 Peterbilt 320...
Miller Big 40 Portable DC Arc Welder Generator (A52377)
Miller Big 40...
2009 Hino 268 Progress VTA72 1500 Gallon Vacuum Truck (A51691)
2009 Hino 268...
Case Maxxum 140 (A50120)
Case Maxxum 140...
2011 International WorkStar 7300 Acid Tanker Truck (A52377)
2011 International...
2004 CATERPILLAR 836G LANDFILL COMPACTOR (A51406)
2004 CATERPILLAR...
