Glulam Beam - Checking Problem
   / Glulam Beam - Checking Problem #101
I'm thinking they should have a person do the repair; it should be on them.
   / Glulam Beam - Checking Problem #102
One thing I would be considering is the reason this happened in the first place is probably down to the timber used to make the beam was the wrong moisture content. It is likely more checks and maybe large cracks will appear over the next few years as the beam drys out at a rate of about one year for every inch of thickness
   / Glulam Beam - Checking Problem #103
Is the engineering fix a proper fix? Or do some people here think it's not?
I think so. I personally would have tried to inject some adhesive in the crack and jacked the center before installing the screws, but that's just me.
Is the manufacturer sending someone, or do you have to do it?
   / Glulam Beam - Checking Problem #104
Yes, the glue isn't accounted for because they are "assuming" the glue is at least equal to if not stronger than the wood. Therefore they are treating it as if it were one solid beam....without glue.
And yes, proper glue should pull wood fibers apart before the glue separates
Got it. It's not as though they added a steel tension rod or something.
I believe that also. The timber had more moisture in it than it should have for an Arizona climate. It left the mill in Oregon and hit the dry/hot air of Arizona and dried out faster than it should. With temps in the 100-115F range and humidity in the 10% range. This caused the checking.
Once dried in on the house, with the AC unit running. It should keep indoor humidity levels of 40-45%.
Unfortunately they are not local. They claim they will pay for someone to come out but they can't come out as they are too far away.
   / Glulam Beam - Checking Problem #107
I would not have had a job if I were oversizing structural members such as headers. Ensure all code issues are followed and not anymore. Some homeowners like to know they are not spending any more on structure than necessary - as the structure is expensive to begin with already.
If the beam was oversized to begin with, then why repair at all? Due to the margin, apparently, the issue is cosmetic. However, if the structural integrity is questioned, now is the time to reestablish the integrity. In the future, investigate the use of LVL or PSL if not exposed to view.
Good Luck
Yooper Dave
Good Luck
Yooper Dave
I tend to "overbuild" on my builds. Last house build I did, engineering said 2,500 psi on concrete floor but I went 3,500-4,000 psi. The same for walls and footings. I always will go bigger/stronger. I would rather spend a little more on structural and that way if something does happen, it's overbuilt to begin with so I have a margin of error. Like these beams, engineering oversized them by about 50% or so with the snow loads. So even if the beam lost 25% of its strength, I am still in the green zone.
I will fix it as recommended just to be safe and the fix is easy enough to do in a couple of hours. It will bring peace of mind.
I know with spec builders, they will not do that. They will do the absolute minimum required by law/code/engineering. They will spend money on finishes (granite, cabinets, etc) as that is what "sells" a house. Not that the footings are 12" wider than needed and the concrete in the footing is 4,500 psi instead of just 2,500 psi. The home buyer never will see the footings or wall structure but they will see the interior finishes and that is what sells homes.
   / Glulam Beam - Checking Problem #109
   / Glulam Beam - Checking Problem #110
I totally get that sentiment. I too tend to overbuild. Nevertheless that is not how most anything is built. I am hoping that the OP can get his beam repaired to the point that it meets the original specs, not the minimum specs.
I know that beams like OP's are built to withstand defects that occur over time but the pictures look like a pretty bad defect. I think if the OP can get a local engineer to look at and OK a repair that is then done by a local entity the repair can be trusted. Of course the beam supplier must sign off on the repair.
Years ago I had a fellow come by my shop needing a LUND boat repaired. Several ribs had broken right in the center. My fix was to make aluminum pieces that fit over the ribs and were two feet long. This way the stress would be over a much larger area than if I just welded up the breaks. So I used aluminum that was at least twice as thick as the rib material and hammer formed it over hard maple forms so that it fit tight onto the ribs. These repair pieces were then welded to the existing ribs while the boat was fixtured so the the cracks in the ribs were closed. The folks at LUND Boats were happy with my repair and paid my customer under warranty who then paid me. Some engineer at LUND looked at my repair and felt that it was more than adequate. If the OP gets the same type of assurance for the repair then it should be OK.
Eric
2019 Ford F-450 Crew Cab Mason Dump Truck (A50323)
2019 Ford F-450...
2016 CATERPILLAR 259D SKID STEER (A51242)
2016 CATERPILLAR...
2017 Ford F-450 Crew Cab Mason Dump Truck (A50323)
2017 Ford F-450...
2016 Dodge Charger Sedan (A50324)
2016 Dodge Charger...
2018 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A50046)
2018 FREIGHTLINER...
John Deere 9450 Combine (A50514)
John Deere 9450...
