jake98
Veteran Member
- Joined
- Nov 10, 2007
- Messages
- 1,824
- Location
- Dingmans Ferry PA
- Tractor
- 53 Cub, 70's JD 410, Kioti 25hst
I'm thinking about welding up a 7' long clamping unit for door rails. Think 1/2" threaded rod is ok for the clamps?
For clamp material, I'd use ACME threaded rod. No. Wylee Coyote doesn't use this to capture the roadrunner.
You can get it fairly cheaply from your local fastenal store...Nuts as well. It's much better than threaded rod, and worth the extra$ you will spend.
