BHD
Veteran Member
I have a project, where I am most likely going to be either using a section of large V belt or a small section of tire tread, for a braking pad,
I plan on using some carriage or elevator bolts on the ends of the rubber section but would like to glue it as well,
what are your recommendations, this would be a brake that would be used to dumb waiter type cart, if the lever is ever activate by the loss of cable tension, the rubber would grip on the metal track, (I want some thing that can grip and compress as well this would be a curve that would self tighten if it is ever needed, the pad (rubber) would be on an eccentric, that the will continue to grip with more down pressure, so I want the compression (I have some old belts off of farm machinery, that will or come close to fitting in a 2" channel iron (which will be the track) or I will cut a section of tire tread, for the pad,
weather strip adhesive,
a super glue type product,
Shoe Goo, Shoe GOO Adhesive product 0710
Free sole, Freesole® Urethane Formula Shoe Repair
any other products one may suggest,
this would be in the elements, not inside, (it may have a cover, but not totally out of the elements or light).
