GlowPlugs in Shibaura D28F
   / GlowPlugs in Shibaura D28F #11
What you describe is the timer light for the glow plugs. When you turn the key on it normally fires up the glow plugs for a few seconds to preheat the combustion chamber. Once the light goes out the engine is then ready to crank.
A compression release is normally a spring loaded lever that you need to twist or hold to keep the engine in the decompression mode. Releasing it lets the engine build compression normally. My last tractor (Bison) had compression release to the right side of the operators foot. The Bison would not start in the winter without the use of that feature. My current New Holland does not have manual compression release but it starts very easily in cold weather.
Did you not get an operators manual for your tractor? If you did you may want to check it out closely to see if its mentioned.
Well I did not get a manual for it but would like to find one. They can come in handy.
2018 Ford Fusion Hybrid Sedan (A56859)
2018 Ford Fusion...
2021 K and K System MB3L S/A Solar Towable Message Board (A55851)
2021 K and K...
2013 International DuraStar 4300 Crew Cab Mason Dump Truck (A51692)
2013 International...
Pallet of UV Solid Hardwood Flooring (A55758)
Pallet of UV Solid...
2016 Nissan Pathfinder SUV (A53424)
2016 Nissan...
Deere 335P (A53317)
Deere 335P (A53317)
