glowplug question for a fx32d
/ glowplug question for a fx32d
Ok one last question. Will dirt or water get in the cyclinder with the threads sticking out the top? Do they seat ot seal at the bottome of the glow plug? thanks again guys. I will have her back in action today.
thanks
wendelin
/ glowplug question for a fx32d #12
They seal at the bottom. The new plugs just don't have that shoulder, and they are a little bit longer overall. Mine work just fine.
BTW, are you replacing the old because they appeared not to work? I found that the easiest way to check was with the battery charger hooked up I could see the drain on the charger's meter. It takes mine @ 3-4 minutes to warm enough to make a difference in cold weather < 27 degrees.
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A57024)
NEW HOLLAND 706 30...
2011 DRAGON 130BBL VAC TRAILER (A58214)
2011 DRAGON 130BBL...
EZ-GO Utility Cart (A55851)
EZ-GO Utility Cart...
(15) Polyethylene Road Bed Protection Pads (A60463)
(15) Polyethylene...
Ford F450 Bucket Truck with Altec AT200A Boom (A56435)
Ford F450 Bucket...
UNVERFERTH 330 - 19-INCH EXTENSION KIT FOR RIP-STRIP TOOLBAR PART # 63186G (A55315)
UNVERFERTH 330 -...
