Glow plugs won't shut off on Mahindra 2810
   / Glow plugs won't shut off on Mahindra 2810 #1
Harvey Smith
Cypress Illinois
2810 Mahindra
Glow plug light on dash came on while mowing and won't go off. Heat strip on top of plugs is heating. Replaced Glow Plog relay but did not solve problem. Could the timer be causing problem? Where is timer located? Or am I overlooking something?
   / Glow plugs won't shut off on Mahindra 2810 #2
If I'm not mistaken the timer controls the relay so you should be able to tell if the timer is staying on by checking the wire to the relay from it. A first quick check would be to see if the plug strip is still live with the relay removed from it's socket, obviously it shouldn't be but if it is there's a short somewhere. Good chance the timer is stuck and keeping the relay on. The timer on my 4110 is in the cowl behind the dash. My dash comes out with 4 screws and then the timer is mounted to the metal cowl, not the dash itself, on the right side. My relay is mounted out in front of the radiator next to the horn and air cleaner.
1998 CATERPILLAR IT28G WHEEL LOADER (A51242)
1998 CATERPILLAR...
2015 Jeep Compass SUV (A50324)
2015 Jeep Compass...
2020 Freightliner Cascadia 126 T/A Sleeper Cab Truck Tractor (A49461)
2020 Freightliner...
2002 International 9200i Truck (A51039)
2002 International...
Pallet Fees (A50774)
2017 Makita HM1307CB 35lb Demolition Hammer (A49461)
2017 Makita...
