Glow Plugs stay on longer than 3 secs
   / Glow Plugs stay on longer than 3 secs #1
indhrasena.reddy
Hi, i want to know that can i get glow plugs that stay on longer than 3 seconds? currently its staying only 3 sec in my 2015 tractor. What are the posible chances that can stay on with my existing glow plugs, & why its getting off quckly.
please reply for this mail.. thank you for your inputs!!
   / Glow Plugs stay on longer than 3 secs #2
Welcome to TBN:D
I am not sure of the system Mahindra uses to "time" the GP's, but my older Ford truck (IH engine) will short-cycle as you describe if one GP is open/bad. I suggest you test each plug with a Ohm meter-they should read near zero resistance.
   / Glow Plugs stay on longer than 3 secs #3
I think there is an update that will make the cycle time around 10 sec
   / Glow Plugs stay on longer than 3 secs #4
Yep
When i replaced my glow plugs last fall they came as a kit. Three glow plugs and a new relay/timer. They stay on for 10-15 seconds.
Ken
   / Glow Plugs stay on longer than 3 secs #5
If your tractor has always had the light on for about 3 seconds, you will need to install the update kit, which consists of a new timer, glow plugs and short jumper harness. If you have your serial number, and give me a call or e-mail, would be happy to help you out i have the kit on the shelf.
Toll free 866-393-0642
Mahindrasales@aol.com
www.mahindrapartsonline.com
Thanks
Scott
Thank you for your valuable inputs its really helpfull.....:thumbsup:
   / Glow Plugs stay on longer than 3 secs #7
Just unplug the wire fron the GP temp sensor on the back of the top coolant outlet. Full 10 sec every time.
   / Glow Plugs stay on longer than 3 secs #8
Mine has always been about 7 secs since new. Light stays on longer, but you can hear the click of the relay at 7 secs. I just hit it twice normally, 4 times if it is really cold like this winter. No problems.
- JC
43014 (A51691)
43014 (A51691)
Heavy-Duty Gooseneck Hay Trailer - Built for Large Bale Hauling (A52748)
Heavy-Duty...
Kubota RTV-X900 4x4 Utility Cart (A50322)
Kubota RTV-X900...
2011 Ford Edge SEL SUV (A50324)
2011 Ford Edge SEL...
