Glow Plugs stay on longer than 3 secs
   / Glow Plugs stay on longer than 3 secs #1
indhrasena.reddy
Hi, i want to know that can i get glow plugs that stay on longer than 3 seconds? currently its staying only 3 sec in my 2015 tractor. What are the posible chances that can stay on with my existing glow plugs, & why its getting off quckly.
please reply for this mail.. thank you for your inputs!!
   / Glow Plugs stay on longer than 3 secs #2
Welcome to TBN:D
I am not sure of the system Mahindra uses to "time" the GP's, but my older Ford truck (IH engine) will short-cycle as you describe if one GP is open/bad. I suggest you test each plug with a Ohm meter-they should read near zero resistance.
   / Glow Plugs stay on longer than 3 secs #3
I think there is an update that will make the cycle time around 10 sec
   / Glow Plugs stay on longer than 3 secs #4
Yep
When i replaced my glow plugs last fall they came as a kit. Three glow plugs and a new relay/timer. They stay on for 10-15 seconds.
Ken
   / Glow Plugs stay on longer than 3 secs #5
If your tractor has always had the light on for about 3 seconds, you will need to install the update kit, which consists of a new timer, glow plugs and short jumper harness. If you have your serial number, and give me a call or e-mail, would be happy to help you out i have the kit on the shelf.
Toll free 866-393-0642
Mahindrasales@aol.com
www.mahindrapartsonline.com
Scott
Thank you for your valuable inputs its really helpfull.....:thumbsup:
   / Glow Plugs stay on longer than 3 secs #7
Just unplug the wire fron the GP temp sensor on the back of the top coolant outlet. Full 10 sec every time.
   / Glow Plugs stay on longer than 3 secs #8
Mine has always been about 7 secs since new. Light stays on longer, but you can hear the click of the relay at 7 secs. I just hit it twice normally, 4 times if it is really cold like this winter. No problems.
- JC
2016 John Deere 6155M (A50120)
2016 John Deere...
2005 Chevrolet Colorado 4x4 Pickup Truck (A51692)
2005 Chevrolet...
Unused 2025 CFG QK16R Mini Excavator (A50322)
Unused 2025 CFG...
2010 Ford Taurus Sedan (A50324)
2010 Ford Taurus...
(4) Stand Alone Texas Panels (A50515)
(4) Stand Alone...
2002 Winston ProSeries 20K Tandem Axle Equipment Trailer (A47384)
2002 Winston...
