Glow plugs question
/ Glow plugs question #1
BTackett
Knoxville, Tn
I am in the process of semi-restoring a Mitsubishi MT372 and before removing the wiring harness the glow plugs were working fine. I installed a new ignition switch ( 5 prong w/preheat Kubota ) and it would turn over but not glow plug. So, I put the old switch back on that worked before ( reason I replaced was that it was sticking in the run position, preheat worked fine ) and it turns over but no preheat now. What could be wrong? I just removed one wire on the glow plug itself. Now preheat will not work.
Any ideas?
I checked my wiring diagram and it shows a 4 prong switch but it was wired 5 prong previously and worked fine.
How exactly do glow plugs work and how can you check them at the switch with meter?
What actually causes the dash indicator to glow when preheating?
Help
Thanks,
Bill
UNUSED RAYTREE RMBD72-72" HYD DRUM MULCHER (A62131)
UNUSED RAYTREE...
2018 JOHN DEERE 26G EXCAVATOR (A62129)
2018 JOHN DEERE...
UNUSED ATS T460 STAND ON SKID STEER (A62130)
UNUSED ATS T460...
2025 LandHonor BS122500G Skid Steer Bale Spear Frame (A60353)
2025 LandHonor...
2025 LandHonor SAD-12-23C Auger Skid Steer Attachment with Bits (A60353)
2025 LandHonor...
2009 STRICK 53X102 T/A DRY VAN TRAILER (A59909)
2009 STRICK 53X102...
