Glow plugs on 7265??
   / Glow plugs on 7265?? #1
Tx Jim
New Member
Coyote Flats,Tx
JD 4255/Kubota M7040 HDC
I just purchasd a used 7265 with 3 cyl. diesel engine. Glow plug lamp flashes on intermittdenty even after engine is warm. I looked in operators manual and it appears that glow plugs should operate from key switch but this one has a push-button above key swich to activate plugs. Thanks for any help,Jim
   / Glow plugs on 7265?? #2
Jim it sounds like your glowplug controller is bad. part no. MA31A66-05100
When they go bad it isn't long before they burn the glow plugs out.
Ned,is this tractor supposed to have a push button to activate GP's? If so how does the GP controller work in conjunction with push button? Thanks,Jim
   / Glow plugs on 7265?? #4
Jim someone must have added the push button switch on to activate the GP's longer. When that light is on your getting juice to the GP's.
UNUSED SDLANCH SDLD 25 HYD DUMP BUGGY (A57192)
UNUSED SDLANCH...
John Deere HPX Gator Utility Cart (A55851)
John Deere HPX...
Caterpillar 257D (A53317)
Caterpillar 257D...
2007 Amkus Rescue System (A53421)
2007 Amkus Rescue...
Mailbox (A55853)
Mailbox (A55853)
2001 Dodge Ram 3500 4x4 Knapheide Flatbed Truck (A51692)
2001 Dodge Ram...
